Need help in maintaining silver!!!
Thanks!
http://www.autopia-carcare.com/quicdetspray.html
http://www.detailguru.com/for113beadxs.html
)1. Buy Mother's clay bar and clay the whole car (per their instructions with a QD) after a wash with blue dawn soap.
2. Since your car is silver I dont think it would have many swirls so you can skip the abrasives and just wash and dry the car to get all the QD off from the clay.
3. Apply Klasse All-in-one (available at some mercedes dealers and Classic Motoring Accessories carries it) in a back and forth motion using a MicroFiber applicator. Then buff off the residue with a 100% cotton terry cloth towel or Microfiber towel (back and forth). Also when applying use very little amount of product (about a nickel sized drop per panel).
4. Then apply Klasse Sealant Glaze in the same manner and remove it in the same manner, however it mest sit on the paint for at least an hour before buffing.
After you have completed these steps your car will have protection for 6 months or more from the elements and will repel dirt and dust better. Then you can use a QD (Quick detailer) such as Meguiars #34 Final inspection, Or Souns acrylic spritz to remove dust after driving. All you do is spray on then buff off with a Microfiber towel or 100% Cotton terry cloth towel. This can only be done if it has only a slight film of dust, otherwise you will end up scratching the finish. If it is soiled or has a lot of dust, you are better off washing the car. Hope this helps! If you have any questions just post or PM me. I know you always post
Will print this out and follow the directions.
Hey Al!
I've seen the pics on your ML and goodness gracious! It's like looking at a mirror!
What are your thoughts about California duster? Is it safe to use it?
Thanks,
Victor
1. When applying the Klasse All in one and SG (sealant glaze) wet the applicator with some Mequiars Final inspection or other NON-CARNUBA QD. And make sure you use 2 different applicators when applying this stuff.
2. To aid in buffing off the Klasse SG I would take a Microfiber towel and run it under water, then ring out as much water as possible. Then go to your car (after the Klasse SG has sat on it for about an hour in LA weather
) and just wipe the car with it and it will be much easier to remove the white haze. Then follow up with a clean dry 100% cotton terry cloth towel or Microfiber towel and your car will shine like this. If you have any questions please PM me or add a reply. I want that E55 perfect!
Very beautiful! Almost made me cry!:p The paint is almost like a mirror! Very nice job! How long did it take for you to detail and applying the wax and coat and the other stuff?
Thanks!
I'm a huge fan of the Honda spray cleaner and wax. I use it on my Hayabusa and my cars. It works GREAT and leaves a clean, polished surface behind. You can use it on a clean or dirty car. Check it out at your local motorcycle shop.
BTW: Great wbesite you've got there! Nice car too!!
