Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
clay bar
Old Apr 24, 2004 | 09:04 PM
2quik's Avatar
clay bar
Can using a polishing compound, or swirl mark remover. remove surface contaminants? Or must a clay bar be used?.... I had rough surface, but used a porter cable and some polishing compound, then it was all nice and smooth.
Old Apr 24, 2004 | 09:20 PM
awiner's Avatar
2003 CL55 AMG
Polishing compound will remove contaminates as well.
Old Apr 28, 2004 | 01:27 AM
2quik's Avatar
will color x by mcguiars do the trick? im not to fond of using a clay bar, so im lookimg for alternates
Old Apr 28, 2004 | 02:00 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations ~
Detailing clay is used for the removal of imbedded debris; a pre-wax cleaner (i.e. ColorX) is a surface paint cleaner. They are formulated for very different jobs and are not interchangeable
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect *so I question everything*
Old Apr 28, 2004 | 02:19 PM
awiner's Avatar
2003 CL55 AMG
Correct. If it is surface contaminants you wish to remove, use a clay bar. Using a polishing compound will work, but why remove/thin some of your clear coat with it to accomplish this ? A clay bar and some lube/soapy water is the easiest way to accomplish the task at hand.
Old Apr 28, 2004 | 08:43 PM
2quik's Avatar
thanx guys, Ok so now which clay bar do u recommend?
Old Apr 28, 2004 | 09:04 PM
RJC's Avatar
RJC
Various
Whatever clay bar you choose, use it with detail spray for best results not soapy water. I've used the kit from Mother's works great and comes with a bottle of spray.
Old Apr 28, 2004 | 09:12 PM
awiner's Avatar
2003 CL55 AMG
Clay is pretty much the same accross the board. You should be fine with whatever brand you can get. Just make sure as stated above to use a lubricant and keep the area your working on slick.
Old Apr 28, 2004 | 10:49 PM
Kar don's Avatar
Mercedes-Benz
excellent points, i prefer the pinnacle, clay magic, and zaino clay. Mothers is ok, meguiars i dislike. The detail spray usually works best, car wash soap and water is cheaper but it can quickly degrade the clay. Polishing using a swirl mark remover to remove surface contaimenents? I dont think thats too smart. Your pad will pick up this specs of crap and could redeposit them in your paint or cause marring or swirling. I would clay and THEN polish, this works better for me.
