Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
cleaning non-removable carpets
Old Jun 28, 2004 | 09:29 AM
Sam 325i's Avatar
Turbo Diesel
how do you clean the carpet's that are attached to teh car?
i usually shampoo floormats and spray them with water to remove soap, but obviously i can't spray water into my interior, so how do i shampoo the carpet that runs from behind the center console down to the floor of the car and over underneath the door sill?
i was thinking a litlte shampoo, good scrubbing, rinse with water from maybe a small spray bottle scrub some more and then suck the water out with a vacuum??
am i off?
Old Jun 29, 2004 | 01:48 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations ~
To hand clean carpet and upholstery:
·Apply cleaning product (303™ Cleaner & Spot Remover) by spraying on the surface to be cleaned. Brush into surface to create foam. The foam will dissolve and suspend soils.
·Blotting and wiping using terry cloth towels now can remove the cleaning liquid. Cleaning interiors by hand is a time-consuming process.
·Brush the carpet to raise the nap and loosen ground in dirt
·Vacuum with a (Metro Vac N’ Blo ®) to lift all the loose dirt from the carpet
Spot treat really bad stains (303™ Cleaner & Spot Remover)
·Using the vacuum, remove the excess moisture and the grime.
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect * so I question everything *
Old Jun 29, 2004 | 04:18 PM
Sam 325i's Avatar
Turbo Diesel
Hey thanks a lot i'll give it a try.
Also - respect to your lineup of cars. Fine rides there, especially the 107.
