Chamois or Water blade?
Thanks!
Thanks for your share in advance!
I use both a blade and a ww towel. Used correctly the WB will not scratch paint
Chamois Leather:
Genuine chamois leather is a unique and natural product, that is extremely soft, flexible, and absorbent
Typically chamois leather is used to dry off surfaces after washing; this is due to the absorbency and softness of the leather, the particles are held within the hollow fibre of the leather, eliminating abrasion. The chamois needs to be damp, but not wet to work.
Made by splitting the skin into two pieces; the selected sheepskins are 100% cod oil tanned to give the luxurious, golden, soft finish that can absorb six times its weight of water.
A Microfiber chamois (woven in a very similar texture) is a machine washable alternative that you don't have to soak before use and it releases dirt, brake dust and stains much easier that natural chamois (Groit's Microfiber Synthetic Chamois) doesn't dry hard, is very absorbent, easier to wring out and it will not `shed' and lasts longer and is less expensive than its natural counterpart.
Modem synthetic materials have gained ground and the use of chamois is being replaced by Microfiber waffle weave technology as they hold more water (approx. 5 times more water, therefore require wringing out less often) and will not `pull' wax from a paint surface. They also do not `dry stiff' like chamois nor do they have the `cod tanning' odour.
Water Blade:
The best-known brand (The Original California Water Blade) is made of medical-grade silicone so it should not scratch. It can be used to remove water without causing scratches by applying very little surface pressure with the blade, wiping with long strokes in one direction only. If there is any grit left on the car after washing, the blade may pick it up and drag it across the paint, much the same as a towel would, this can be avoided by wiping the blade with a clean damp towel after every pass. The water blade should be protected when not in use. If it is crushed in storage, the edge may take a set and leave a stripe of water on the car, the water blade comes with a protective plastic case, use it for blade storage.
Like any tool, the water blade does require a little bit of technique and practice. The first few times I used mine, it tended to chatter on the surface, resulting in incomplete drying. It turns out this is eliminated by using just the right angle and pressure on the blade. Smoothness can also be affected by the surface condition of the paint (wax, sealant oxidation, etc.) and any coating that might be on the water blade itself.
Do not use a water blade to remove rainwater as there could be road grit on the paint surface or the rain may contain impurities that could scratch the paint.
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
Spritz the surface with a QD as you dry to help remove water spots and give a great shine.
Chamois, natural or synthetic, will harbor grit. I do not recommend them.
Anthony
I use a high quality terry cloth towel when I dry my car after washing. It gets washed and dried after every use. I have not had to reapply any polish or wax to my car in a year and it gets washed 2-3 times a week.
I have been using compressed air and a "real" cotton towel. It works for me.
If you have a clean waterblade and you know how to properly wash your car you won't get scratches. If the clean waterblade is scratching your car then you probably need a lesson on a foammaster and/or two bucket washing and rinsing.
To address the "definitely wouldn't user either of the two": I and number of other people have used the Water blade on numberous cars including black cars. Never a single problem with it but you're obviously going to stick with what works for you.
