Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Care for ceramiclear (nanotech paint)?
Old Nov 30, 2004 | 01:07 AM
neoprufrok's Avatar
Just curious - here's a thread about my dilemma with it on amgpower.com - don't want to repost a long post so here it is:
amgpower.com post regarding care for ceramiclear
Old Nov 30, 2004 | 10:12 AM
MerlinMc's Avatar
2005 C55
Do all of the '05 C55s have the ceramic paint?
Old Nov 30, 2004 | 10:58 AM
Kar don's Avatar
Mercedes-Benz
yup, i wish i had it on my C.
OK, I am first moving this to the detailing section. But you are pretty close to right on with your procedure. Menzerna is my first choice when it comes to german paint, esp the nano paint. In my opinion I would be very surprised if you even had to use the Final polish on a new car with this paint. Here is what I would do, skip the clay and use a chemical decontamination process and then move straight to AIO and SG. I would apply AIO via pc with a mild polishing pad.
Old Nov 30, 2004 | 01:24 PM
neoprufrok's Avatar
Thanks for the advice. Have you heard anything regarding Menzerna selling a new polish formulated specifically for the ceramiclear?
Old Nov 30, 2004 | 10:52 PM
MerlinMc's Avatar
2005 C55
Questions for AlBoston
AlBoston -- do you think Zaino Z-2 + ZFX would work well on my Silver '05 C55? Do you think the Klasse AIO + SG would be better than the Zaino? You also mention chemical decontamination. Would product would you recommend? Thanks very much.
Old Nov 30, 2004 | 11:28 PM
DiamondNoir2K5's Avatar
'05 C230K SS
I use Z2+ZFX on my '05 C230K (which has nano-clearcoat) and it looks great.
Old Nov 30, 2004 | 11:55 PM
Kar don's Avatar
Mercedes-Benz
merlin for silver I would have to say I prefer Zaino... I am still not sure if I like K or Z better on black. Neo, I believe that menzerna's new Final Polish II and Intensive polish is formulated to work on nano paint. I can tell you that I used Intensive polish on a trunk of an SL55 (non nano... and it swirls if you breath on it) and it did not leave any haze or towel marks! Very impressed. Mercedes-Benz supposedly uses these products in their assembly process!
Old Dec 1, 2004 | 02:01 AM
gmdebruyn's Avatar
2005 E55, 2010 ML350
Al,
I posted in another thread, but it relates to what you are recommending and talking about.
https://mbworld.org/forums/detailing-automotive-care/89921-chrome-cleaner-protector-interior-cleaner-protectant-rubber-seals-plastic.html
I just got a black (regular black) E55. I want to set it up correctly and then maintain the paint properly. What would you recommend? Thanks in advance for this. This is one area where I am very much still learning.
Thanks,
Gareth
Old Dec 1, 2004 | 12:06 PM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations
Scratch Resistant Clear Coat:
Various paint manufacturers working in conjunction with Mercedes Benz to formulate a new hard, scratch resistant clear coat. Pittsburgh Plate Glass (PPG) have formulated Ceramiclear, utilizing nano technology that creates a highly cross-linked network for superior resistance to scratches, acid etching from environmental hazards such as acid rain, tree resin and bird excrement.
BASF and Mercedes Benz developed a special polish for use on ceramic clear coats for use on the assembly line. This polish was originally developed for their version of an ultra hard ceramic coating formulated in 2003 but never put into production and shelved for the time being. Menzerna have formulated a polish for the 2004 Ceramiclear for use by detailers, Intensive Polish and Final Polish II
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
Old Dec 1, 2004 | 02:26 PM
Kar don's Avatar
Mercedes-Benz
interesting info! I was pretty sure the new Menzernas were meant for use on ceramiclear... thanks for confirming Gareth, I will reply to your post once I get home.
Old Dec 2, 2004 | 12:02 AM
gmdebruyn's Avatar
thanks alboston! look forward to hearing back.
Gareth
Old Dec 4, 2004 | 05:49 PM
Kar don's Avatar
Mercedes-Benz
Gareth,
For black I really like klasse and Zaino. The picture in my signature is of my C320 after 5 coats of Zaino's Z5 and in the background is victoryroad's CL55 (has nanopaint) with several coats of Z5. I must say that on black zaino is absolutely stunning, very stunning. I would recommend doing a chemical decontamination and then applying zaino or klasse afterwards. I will soon be posting pictures and hopefully a video of a black SL55 I decontaminated and applied klasse on.
Old Dec 4, 2004 | 08:02 PM
gmdebruyn's Avatar
thanks al! what is the chemical decontamination? where do you get such a product? how does it compare to clay? i'm in california/bay area. not much acid rain here. which would you recommend?
Old Dec 10, 2004 | 07:56 PM
Brian_I.'s Avatar
w211 & w124
What is this decontamination process he speaks of?
Old Dec 10, 2004 | 08:00 PM
gmdebruyn's Avatar
i'm still awaiting an answer as well..
Old Dec 11, 2004 | 06:57 PM
Chris 45971's Avatar
2005 SL 500
How do you know if you have "Nanotech Paint"? I researched and saw that Mercedes started using the new paint in 2004. Is it determined by the build date? Do only certain models of Mercedes get Nanotech Paint? I have an 05 SL 500 with a build date of 11/04.
Thanks to whomever responds.
Old Dec 11, 2004 | 08:10 PM
Kar don's Avatar
Mercedes-Benz
sorry guys, i have been pretty busy and I will soon have a post fully explaining this process.
Chris: your 05 SL500 has the new nanotech paint, check the sticker inside the drivers door jamb and look for the paint code. For example, If the code say "C040" you have black nanotech paint.... the "C" prefix to the 3 number paint code means you have the ceramiclear clear coat.
Old Dec 12, 2004 | 06:31 AM
2005 SL 500
Thanks again All Boston.
The color of my car is Brilliant Silver. Which wax/polish do you suggest using on this color (Ceramiclear Clear Coat)? I am new to this and looking to purchase the best premium product for use with my car. Judging by your sig pic, you seem to be a professional at this. Any advice that you can give is greatly appriciated.
Old Dec 17, 2004 | 03:03 PM
Kar don's Avatar
Mercedes-Benz
gareth and brian,
The process is a 3 step process using the finish kare decontamination kit. It removes all adhesives, old waxes, oils, grease, tar, ferrous deposits, water stains, rust stains, completely and keeps them from coming back. Also the huge plus of the kit is that as you pull and dissolve these particles out of your paint it will not scratch, unlike clay which scratches like hell. I was blown away by the process and how effective it was.
Old Dec 17, 2004 | 03:57 PM
gmdebruyn's Avatar
thanks AB,
where does one get this kit?
Gareth
Old Dec 17, 2004 | 06:33 PM
Kar don's Avatar
Mercedes-Benz
Finish kare sells it directly, www.fk1usa.com
