Which is better in terms of reliability and power?
Old May 6, 2006 | 12:59 PM
deltadude388's Avatar
School bus
Between the 2.5l inline 5 turbo diesel Vs. the 3.0 inline 6 24valves diesel motor? I am looking at a few of these W124 series sedans. The 95' models with the inline 6 seem a little nicer with the updated interior and all.....
Old May 6, 2006 | 03:04 PM
H-townbenzoboy's Avatar
1981 300SD TurboDiesel, 1982 300D TurboDiesel
I think both variants are nice, they both reliable, but there's some catches. The OM606 (inline 6) will give you a troublesome time trying to replace the glow plugs. You have to remove the exhaust manifold to get to them. The OM602 (2.5L inline 5) doesn't have many troubles either, though some models may have timing chain problems, not sure if the 300D 2.5 is included though. So, after that, I'll let you come to your own conclusion.
Old May 6, 2006 | 03:06 PM
School bus
How often do Glowplugs need to be changed in I live in the moderate climates like CA?
Old May 8, 2006 | 12:03 AM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Wink Glow Plug Changes in Milder Climates.
Our '99 got to the point where it had one or two bad glow plugs.
It always started and when it was the coldest in the winter, down in the forties in the garage on
the coldest mornings, it would always start up right away and within seconds, those
cylinders with the bad glow plugs would light off on their own from compression.
I saw no need to have it fixed as it always started although it
wasn't the smoothest running motor for a couple of seconds.
If it ain't broke, why fix it?
Old May 8, 2006 | 06:25 AM
kort677's Avatar
'05 e320 cdi, '05 lexus rx330
Originally Posted by Green E-300 DT
If it ain't broke, why't fix it?
because it is broken?
Old May 8, 2006 | 02:06 PM
Thumbs down Really?
That's all well and good if you're loaded with money, but I'm not, and I simply couldn't see spending
several hundred dollars on something that I did not consider to be necessary to make it
run a little smoother during the first couple of seconds.
Old May 9, 2006 | 02:39 PM
School bus
so anyways, I won the bid on the 3.0 inline six E300 diesel, hope to see it in a couple of weeks. 200K miles, this is going to be my commuter car to work.
Old May 9, 2006 | 05:18 PM
DslBnz's Avatar
Whether or not you live in a mild climate, they usually go out as frequently as sparkplugs on an '80s Merc. Every 20 - 30K miles, I've heard.
The reason is because the later Mercedes have something called "Afterglow" in which the glowplugs remain hot up to almost a minute after starting the engine.
Old May 9, 2006 | 08:49 PM
School bus
ok, is there 1 or 6 glow plugs for the motor?
Old May 10, 2006 | 03:48 AM
One for each cylinder.
