Air is or is NOT okay in fuel lines?
Old Apr 15, 2007 | 02:33 PM
dylancarter's Avatar
2009 c300
I have what I consider a large amount of air in my fuel lines. 2 seperate mechanics have told me "this is normal" - true? I have replaced all the clear lines and orings, also the fuel shut off was leaking - replaced entire unit. Car runs good, just wondering if air is sign of something bad???
Old Apr 15, 2007 | 03:00 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Year and model really helps.
What's a large amount of air to you? If it's a single large bubble in the clear filter, it's normal.
Old Apr 15, 2007 | 03:09 PM
2009 c300
Sorry - 1999 e300td
The air is while running - the fuel in the clear lines ( all of them ) almost,but not quite, looks like foam. That's how many bubbles. It looks to be 30-40% bubbles. Seems like a lot to me. But like I said, car idles and runs great.
Old Apr 15, 2007 | 06:15 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Volkswagen experience only
Originally Posted by dylancarter
Sorry - 1999 e300td
I had the same experience with my 1999 VW Jetta TDi. Lots of bubbles but no problem at all. I was worried insufficient fuel or too much air is going into the engine but the engine ran well.
The only problem was a noisy turbo when it starts spinning.
Old Apr 16, 2007 | 10:42 PM
SmokinCummins's Avatar
Air in fuel will hurt fuel mileage, and increase black smoke.
Old Apr 16, 2007 | 10:45 PM
rsatmans's Avatar
None
Air in fuel lines is bad. Should be causing the engine to knock louder and idle rough.
2009 c300
After reading everything I can I am thinking that the o-ring in the pre-filter may be bad. I am picking one up tomorrow - along with a new pre-filter and main filter.
I'll let ya'll know what happens
Old Apr 16, 2007 | 10:49 PM
2009 c300
It's a little rough when I first start it, then mellows out.
Old Apr 27, 2007 | 11:33 PM
2009 c300
$10 fix
Well ya'll - $10 fixed everything. I changed the fuel filter and pre-filter, and still had all kinds of air in the lines. Grrrrrr. I had just had my fuel lines changed, what else could it be. I looked at my fuel line and 2 of them did not look like they had been changed. I changed the one from the heater(?) to the prefilter. When I took it off there was NO O-RING on one of the sides!!! Uhh, maybe that was it? Clicked my new $10 line on, and started her up. Runs like a champ and NO air in the lines.
Old Apr 28, 2007 | 12:00 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Air=bad
You should have zero air!
One bubble is too much!
Any body that tells you differently is wrong.
