what is this?
It looks like some kind of heat dissipation coil.
Is this present on your GL 320 CDi?
The black metal tube runs right across the middle of the radiator.
Power assisted steering is present on most vehicles. What is not commonly known, however, is the fact that some power steering systems reach temperatures that significantly reduces the life of the system.
The power steering system creates pressure, in turn creating heat. The rise in the temperature of the system can create loss of assist as well as leakage. This primarily occurs when the temperature of the fluid exceeds the specification of hoses and of the seals in the pump.
Power steering oil coolers are commonly found on higher performance or specialty vehicles, vehicles with increased trailer towing capacity, large car platforms, SUV’s and Trucks.
Automakers continue to stretch warranty periods to win the end consumer’s business and power steering oil coolers are one of the components used to achieve these extended warranty periods and ensure a robust product.
