1999 E300dt oil question
I am looking for advice if I am using the best engine oil for my 1999e300dt. I currently use Delvac Synthetic, but have heard a few things about Amsoil and Mobil one. Also would moving to a 5w-30 give me more mpg? Any damage potential here? The car is amazing and has 145k miles and I plan to get it to at least 300k if not more. Thanks!
Rob
If you aren't having any problems (excessive oil consumption or sludging) then stick with it.
Changing to 5w-30 won't help your mpg by much, but may be a good idea if you live in a colder area, otherwise stick with what works for you.
There is no 5-W30 oil that is C rated for Diesel engines, using it will damage the engine because it can't handle the soot.
http://www.liqui-moly.com/liquimoly/...id/d_1340.html
The reason is that it is the only FSS approved diesel-specific motor oil that has the full SAPS content, unlike the 229.31/51 oils that have low SAPS for DPF compatability.
They have four or five different diesel oils. All of which are better than Mobil's.
Amsoil is the only oil I use. I graduated from Mobil One years ago...
Rob
There is a business in OH that is importing a Mobil product from Europe, it's 5W30, and does meet MBz specs. It's aimed at the cars equipped with DPF. It should prove to be a superior lubricant. However, switching from a xW40 to and xW30 would provide a fuel economy bump in the 2 -4% range, no more.
FYI: AMSOIL purchases its basestocks from Mobil.
Amsoil buys OIL STOCK from major manufacturer's like Mobil, Sunoco, etc and uses that as a BASE for their oils. As does Royal Purple, Red Line, etc. They are not an oil company, they have to start with the same stock as everyone else.
Their final product has NOTHING in common with anyone else's products other than the initial base.
You're typing to an Amsoil dealer who has done all the leg work.
Your engine requires oil meeting MB229.5
It might make one feel "manly" to use something called "truck and SUV" or "turbodiesel truck," but the fact is the only oil from Mobil that meets Mercedes specification is 0W-40 European Formula.
You two have alot in common...
But, you don't know of a higher quality oil than Mobil 1 0W-40.
Maybe something from Fuchs or Total ... maybe a little, only.
All are installed at factory--which certainly knows its oil.
The world's come a long way since the 1970s, i.e. the 240D era. So has engine design and so has motor oil research and development. Yes, you may use MB 229.3 oil in '97 and earlier engines ... which is of course not relevant to this thread.
It's only an ego trip to think diesels different. Or what some marketing hype has attempted to convince. Everyone wants to be different, and guess what--marketers know this.
If Mercedes says the OM648 can go 13K miles change interval on Mobil 1 European Formula 0W-40, I suspect they're correct. Especially since the interval is longer in Europe.
If Mercedes says the OM642 can go 10K miles change interval on Mobil 1 Formula M ESP 5W-40, I suspect they're correct.
I rather imagine they've tested it.
You can too.
There is NOT a different MB motor oil spec for diesel engines vs gasoline Mercedes engines. You can take to the bank this is not Mercedes making an error. They are, of course, the first manufacturer to install diesels in cars, the inventor of the internal combustion gasoline engine (and, in fact, the automobile) and were closely associated with Dr. Diesel.
PS: Yes I know Mercedes' approval of an oil depends on the oil manufacturer arranging and paying for an independent test and submitting it to Mercedes. This obviously means there are oils out there not on the list and not able to state they meet the spec that indeed would if tested. Very little reliable information available to substantiate which those are, however. Pretty easy and no compromise whatsoever to stay with officially approved and listed products.
1: William Barnett 1838
2: Nicolas Joseph Cugnot 1769
3: They never worked together and Diesel died 20 years before Mercedes ever developed their first automotive Diesel.
OK, Rob, are you still out there? here's a link to the '07 product guide direct from MBz:
http://mbca.cartama.net/showthread.php?t=28048
I think you need to see pg3.
Take care.
Refer directly to the latest product guide. Kent is 100% correct with his statement about the gasoline and diesels using the same quality standard apart from the newest diesel autos, which mandate 229.51. The API reference is bordering on meaningless.
MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. ACEA A3 B4. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils.
ROTFLMAO!!!!!!!
And you won't find a bigger Richard Cranium ego than The king.........
Those of us that know the truth know you can use diesel oil in gas, and vise versa. The king "knows" differently, but then again, what would a guy who drives a replica Volvo know?
In Europe, they are not allowed to be called synthetic. That is reserved for true Group IV/V oils.
Pentosin, Liquimoly, and other European firms differentiate between synthetic,HC, semi-syn, and conventional oils, and their (real) synthetics are excellent.
