e320 smokes under heavy acceleration
Seems there was a thread recently with the same subject if not the same title. You could search.
Ours did it from brand new and AFAIK it's normal.
The solution is the latest V6 with particulate filters.
2005 E320 CDI, 2003 SL 500 sold, 2008 CL63
Mine also smokes if I nail the accelerator hard but only when I haven't accelerated hard recently. It seems that I get some buildup in the exhaust system and then when I nail it hard the particulate breaks loose. Afterwards, even on repeated hard acceleration I can't notice any smoke. All this makes me think I should just save up for that occasional tailgater and then let them have it.
When our '06 E leaves the garage, the place is filled with enough diesel smell to choke you.
You can stick your face in the exhaust of our GL and never smell a hint of diesel. In fact, it smells like a laundromat, i.e. just hot and humid.
Mine does the same...big puff of smoke during heavy throttle tip-in if heavy throttle hasn't been used in a while (for instance, after the wifey has it for a few days).
It has done this since new, but seems to do it more so now (20k miles).
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Sorry, no particulate filters on the '05 and '06.
2005 e320 cdi
Mine also smokes if I nail the accelerator hard but only when I haven't accelerated hard recently. It seems that I get some buildup in the exhaust system and then when I nail it hard the particulate breaks loose. Afterwards, even on repeated hard acceleration I can't notice any smoke. All this makes me think I should just save up for that occasional tailgater and then let them have it. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Tailgater vs CDI smoke
Just read your idea about recycling of CDI smoke. I can wait to try it. Hope you didn't to wet with IKE.
As this happened only a couple of times and there were no signs of CEL or any warning lights I assume that all is well with the fuel mixture.
The black smoke from my car is not rich and thick like what you would see at diesel truck drag strips but rather a few intermittant anemic puffs.
