1993 300d Reset codes
Old Feb 7, 2010 | 10:48 PM
DeveloperX's Avatar
1993 300D x2 - 2001 Excursion Power Stroke x1
Ok built the code resetter, then realize my 300d does not have pins 14 and 8. Those pins are blank on the X block.
How do I use the code resetter to clear the codes since I do not have pin 14 and pin 8.
I can hook up to pin 1 and 16 but is that enough to reset it?
Old Feb 8, 2010 | 03:17 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
1993 does not have a CEL. Put a normal wastegate on the turbo and plug the EGR vacuum tube and all computer limits on engine performance will be eliminated.
Old Feb 8, 2010 | 08:12 AM
DeveloperX's Avatar
I would rather clear the codes, wait for them to come back then begin fixing what is causing the problem.
My mechnical can clear the codes.
But lets say I follow you advice.
Where do you even get a 'Normal waste gate"? (for a 1993 300d)
Thanks in advance.
Old Feb 11, 2010 | 07:39 AM
DeveloperX's Avatar
I really need an answer to this one, can someone (Aurthor) please chime in.
The car is stuck back in limp mode now and I am not about to take it back to the shop just to have the codes reset.
Please assist, need to reset the codes on a 1993 300d.
Old Feb 11, 2010 | 02:01 PM
TMAllison's Avatar
09' E320
Go to peachparts.com and do an advanced search for "Arthur Dalton code reader". "Blink codes" might work also.
It will pull up a couple of thousand hits. You'll have to weed through the posts to find the codes and procedures for your year.
Old Feb 11, 2010 | 09:56 PM
DeveloperX's Avatar
Thanks, already built the Arthur Dalton code reader..
Needs to use pin 8 or 14 depending on the subsystem you are pulling codes from.
However a 300D 1993 has no pins on 8 and 14.
They are blanks, and I am having no luck finding how you reset or pull the codes on these desiels.
Old Feb 12, 2010 | 08:08 AM
DeveloperX's Avatar
Good call. I found the the X block pin 4 is the one I needed for the diesel codes.
Took a ton of reading, but I think that is it.
Pin 1 ground, pin 4 neg side of led, last is power (use battery).
I will post more once I finish testing.
