Gas in tank
Old Oct 14, 2010 | 11:29 AM
michiganmichael's Avatar
mercedes 320 cdi
Gas in tank
My wife accidently put 7 gal of gas in my 2006 320 cdi before I could catch her. I stopped, and put the balance of 11 gal of diesel in the tank. I do hear a little more "engine knock" Should I drain the tank, and if so...where is the drain plug/petcock?
Any help would be appreciated
MM
Old Oct 14, 2010 | 12:53 PM
lkchris's Avatar
'10 CL550, '12 GL550
The drill when this happens is ...
call a flatbed tow service
have vehicle transported to Mercedes mechanic
do NOT start the engine.
Old Oct 21, 2010 | 11:56 AM
mhess427's Avatar
2001 Saab 9-5 Aero, 2003 Suzuki SV650, 1982 Mercedes 300TD
I've seen procedures on youtube I believe. Hopefully no serious damage was done!
Old Oct 27, 2010 | 07:36 PM
ThaddeusMaximus's Avatar
None yet
Oh jeez.... Nothing like turning 14 gallons of fuel into 14 gallons of hazardous waste...
Old Oct 31, 2010 | 04:54 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
You need to do far more than that, you need to completely flush the fuel system.
IF the high pressure fuel pump and injectors aren't damaged then you'll only have lost a tank of fuel and the expense of flushing.
Old Nov 21, 2010 | 10:01 PM
scootr29's Avatar
My advice is to my wife....
Take the key and put it in her pocket and then call me.
Old Dec 1, 2010 | 06:52 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
This is why my wife has never, in 41 months of GL320 ownership, filled the tank. That's my job. Barring that solution, the flatbed to the MB shop is the only other answer.
Old Dec 13, 2010 | 12:12 PM
Brunhilde's Avatar
240D
Don't be too hard on your wife. The service shop I just got my car back from, did exactly this. And had the nerve to charge me for both the engine work and replacing the fuel pump, cleaning and re-priming the engine.
Yeah, an official MB service shop did this. From now on, I'm sticking with the Haynes manual. They offered to fix the thing I originally brought it in for (bad thermostat), but at that point I didn't want them ever touching my car again, you know?
