Resealed ONE delivery valve, can not start the engine now
If air get into the fuel pump, then it has to be purged.
Charge the batt. and then see if you have fuel delivery to the other cyl.
If the battery is weak then the glow plugs could be pulling power away from the fuel control valve and that might prevent any fuel delivery
If the fuel control valve is in no fuel positon you will not get any fuel delivery to the injectors
Waited 10 sec - spin the engine. False start. Repeat. The voltage now is about 12.5 V falling to 11.2 V. Same story. Repeat. couple more times. The final voltage on the battery was 12.3 V going down to 10.96 V with ignition on. I was spinning the engine for about 20 sec each time and about 30 sec on the last attempt as the engine caught on on 2 or 3 cylinders so the battery and the starter load was reduced. Still a little rough on idle, BUT the cylinder that was misfiring constantly on idle before is working now! No more hard shaking on idle. I hope that my DV valve rebuilding solved the problem. Now back to the glow relay timing issue. Still there. The light does not go off before the engine started, but does go off when the the engine is started. Assumption: glow plugs are still good, timing mechanism died. What can it be? There only few chips inside. A capacitor? Thanks a lot to everyone who helped. Back to debugging other issues. At least I know that the engine still works
