2008 Sprinter 2500 diesel transmission trouble!
Old Nov 16, 2011 | 07:40 PM
clarive's Avatar
2008 sprinter 144
Had transmission flush because I had trouble getting out of park smoothly. Sometimes there would be a noticeable "thunk" as is shifted from Park to Reverse. What other engine components would cause this to happen. I find if move shift lever with and controlled/smooth effort I can mnimize the "thunk".
Old Nov 17, 2011 | 01:16 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Is the idle speed a little high ?
Old Nov 17, 2011 | 09:57 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
are you parking on an incline (even a slight one) that is loading up the system? Try applying the parking brake with the vehicle in Neutral. Let the brake take the vehicle load. Then put in in Park.
