Glow plug control module - 320CDI
Old May 19, 2012 | 12:19 PM
mbhouston's Avatar
2008 ml320 CDi
Hi,
Does anyone know where the glow plug control module is located? Any pictures will help. I have a 2008 ML 320 CDI.
Thank you,
MBP
Old May 21, 2012 | 08:57 PM
mbhouston's Avatar
2008 ml320 CDi
Plutoe,
Thanks for the reply. I have an ML 320 cdi - 2008.
Regards,
MP
Old May 23, 2012 | 09:11 PM
mbhouston's Avatar
2008 ml320 CDi
Hi Plutoe,
Thanks for the reply. I will trace this back. A picture will really help me.
Regards,
MBP
Old May 24, 2012 | 10:49 AM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
look here:
Old Jun 8, 2012 | 08:12 PM
mbhouston's Avatar
2008 ml320 CDi
I replaced the control.....works like a dream, CEL is now off. Cost was $130 for unit and 20 minutes to install.
Thanks for all the help.
MBP
Old Jan 23, 2019 | 02:03 AM
SiRudBi's Avatar
Top Answer: 1
2017 AMG C 43 (W205); 2019 E 300 (W213); 2008 ML 320 CDI (W164)
I was 5 hours into a long trip when the glow plug light came on for a minute and then went off again. Three minutes later, same thing. Eventually, still on the same trip, the glow plug light came on and stayed on. The next day the vehicle started as normal, but now both the glow plug light and the CEL were on. Three days later the vehicle started to have difficulty to start when cold. The OBD II scanner gave an error "Communication to Glow Plug Control Module lost".
I replaced all 6 glow plugs and the glow plug control unit with new parts from the Mercedes dealership. I took care that the part numbers and the glow plug Voltage of the new parts were correct for the VIN of the vehicle and also that the new part numbers correctly cross referenced to the old part numbers. The glow plug light and CEL still remain on, or come back on even when the error code is deleted on the OBD II scanner. I checked all the fuses in the fuse box in the engine bay. No sign of damaged or loose wires or broken connectors. Everything in the engine bay is clean and in good order. I don't know what else could be wrong. Some help would be appreciated. Thank you.
Old Jan 23, 2019 | 11:53 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
codes ?
Old Jan 23, 2019 | 02:46 PM
SiRudBi's Avatar
Top Answer: 1
The scanner gives reading: 'U0106 Lost communication with Glow Plug Control Module'.
Old Jan 23, 2019 | 03:03 PM
SiRudBi's Avatar
Top Answer: 1
If interested, I have more photos and information on my issue in the link
2009 Ml320 Blu Tech cylinder numbers
https://mbworld.org/forums/m-class-w...r-numbers.html
Old Jan 23, 2019 | 07:30 PM
kajtek1's Avatar
https://www.obd-codes.com/u0106
Out of 5 possibilities this site list, 4 are bad wiring.
Get a can of MAF or other cleaner, wash all the plugs on the line to module and get good light to observe the harness for cuts.
Old Jan 24, 2019 | 12:25 AM
SiRudBi's Avatar
Top Answer: 1
Thank you very much kajtek1. The problem was indeed a poor earth wire connection to the cylinder head. After cleaning the wire lug and connecting surface on the cylinder head with some sandpaper, the error code, CEL and Glow Plug Light error are gone. The engine again starts first time like it always used to.
This earth wire connection was very slightly loose and just a little corroded. Cleaning and tightening the connection resolved the error code, CEL and Glow Plug Light error.
Old Jan 24, 2019 | 04:55 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Glad you found it. I think I'll run thru my engine compartment this weekend and check for chafing and loose/corroded connections. This is a great thread.
Old Jan 25, 2019 | 12:59 AM
SiRudBi's Avatar
Top Answer: 1
Took some photos ...
New ceramic type Glow Plug takes an 8 mm tube socket.
Glow Plug locations on cylinders 1, 2 and 3.
Glow Plug locations on cylinders 4, 5 and 6.
Set-up for doing some Voltage checks on the Glow Plug Control Module.
Voltage readings for each contact inside the socket on the Glow Plug Control Unit for the multi-wire electrical connector.
Old Mar 10, 2023 | 06:11 PM
vitamin475's Avatar
jeep wh crd
this data is of a good glow plug module? Or of the bad one?
