Assambly instructions: Inlet manifold servo protector For MB C, E, CLK, R, GLK,……V6
Old Jul 4, 2012 | 02:40 PM
cobogol's Avatar
W209 320 CDI V6; W210 320 CDI I6
1.-Remove the engine cover, it is fitted into the lugs.
2.-Remove the air intake duct, loosening the edges with a screwdriver and the front binding turbo and disconnecting the electrical connections.
3.-Place the accessory.
4.-Repeat steps in reverse order for assembly
Old Jul 4, 2012 | 02:42 PM
cobogol's Avatar
More pics
Old Jul 6, 2012 | 02:20 AM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
What does it do? Goes my 2011 GL350 need it?
Thank You
Old Jul 6, 2012 | 04:45 AM
cobogol's Avatar
Hello, it protects the servo manifold of the admisión cause in the OM642 engine, the hot oil can entry in the servo causing its a failing and an expensive breakdown.
I don´t know if it´s fits well in your engine.
You can see a lot of related problem with this in the mb forums, just look by inlet servo manifold OM642
Old Jul 26, 2012 | 03:47 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Can anyone explain what happens when this servo starts failing? If the servo is having problems, could this explain low fuel pressure codes?
Old Jul 26, 2012 | 04:14 PM
cobogol's Avatar
The sensor don´t measure well, so then the proportion that goes into the engine is less than in a normal situation cause the car detects that the sensor is break. Then the car can´t overtake 120km/h or so with less than a half or power.
Hope this helps.
Old Mar 20, 2013 | 09:23 PM
tempestv8's Avatar
2006 W164 ML320 CDI
Hi cobogol,
I like the look of this curved metal sheild, which will divert away any leaked oil away from the swirl motor underneath.
Is this metal shield a genuine Mercedes part, or is it a custom made item?
If it is a Mercedes part, do you have the part number to order it?
Thanks in advance!
Old Mar 20, 2013 | 09:29 PM
cobogol's Avatar
Thanks, It's custom made, designed by my father and me. Some Mercedes dealers also bought it from us (Switzerland, Holland,...)
Best
Old Mar 20, 2013 | 11:30 PM
tempestv8's Avatar
2006 W164 ML320 CDI
Thanks for your quick reply.
The fabrication looks top class! It looks very high quality, a bit like a genuine Mercedes part!
Old May 13, 2014 | 03:55 AM
Gaetano.oliva1's Avatar
W211 280 cdi
Hope this helps.
Hi.
How can I have the piece?
I live in Padova (ITALY)
Thanks in advance
Gaetano Oliva
Old May 23, 2014 | 09:30 PM
pellar06's Avatar
2007 E320 2009 CLS63
I would also be interested in one. Could you PM me the cost shipped to the US.
Old Dec 7, 2014 | 10:41 PM
efzauner's Avatar
2005 C240 2011 R350
where is this servo manifold? what does it do? how does the oil get in?
thank you
Old Dec 8, 2014 | 11:47 AM
cobogol's Avatar
The servo is just under the shield. That shield is not included in the engine, you should put it to avoid this failure.
Old Dec 10, 2014 | 09:19 PM
efzauner's Avatar
2005 C240 2011 R350
I have had oil leaks in that area. The first time the dealer did a lot of warranty work on the oil cooler. I don't think that was the problem. I myself t hen changed that orange PCV/preheater connector and it was much better. I clean the area regularly with orange cleaner and pressure wash! it stays pretty clean now.
Old Dec 11, 2014 | 06:24 PM
cobogol's Avatar
The problem are the seals but this platens protects from any oil leak that worn seals produce. You shouldn´t clean that area with pressure wash due to the servo can be damaged with water in the same way that it´s from oil.
Best regards
Old Jan 6, 2016 | 09:01 PM
mike millspaugh's Avatar
2007 e320 bluetec
how can i buy one?
Old May 14, 2017 | 05:57 PM
cobogol's Avatar
Instructions:
https://www.youtube.com/watch?v=2v-j...ature=youtu.be
Old May 18, 2017 | 10:52 AM
DanD.'s Avatar
2018 GLC 4MATIC
Originally Posted by mike millspaugh
how can i buy one?
+1. Please let us know how we can buy it from you.
Ship to US.
Old May 18, 2017 | 11:55 AM
cobogol's Avatar
Hello, you can write to my email address: jcanal82@hotmail.com
