Does the ML, GL, S and SPINTER have the same motor?
Old Jan 12, 2013 | 01:26 PM
300DTurbo's Avatar
300D Turbo 1984
I would like to confirm that the same 3.0L Turbo diesel V6 powers all four of these models?
If this is true im impressed at what a little 3.0 can do.
My 1984 3.0 Straight 5 Gets me from naught to 60 in 34 seconds with the turbo screaming.
Old Jan 13, 2013 | 02:51 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Yes they do w/different power setup. There is a rumor about using 2.2 diesel in Sprinter.
Old Jan 15, 2013 | 12:01 AM
300DTurbo's Avatar
300D Turbo 1984
awesome, the little 3.0 that could.
Old Jan 16, 2013 | 11:26 AM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
They do, but the newer versions have better turbos so they produce more power. Also, most of the Sprinters are slightly detuned, and in Europe would be sold as the E280 and E300 if they were in an E-Class, despite having the same engine.
Old Jan 17, 2013 | 09:49 PM
300DTurbo's Avatar
300D Turbo 1984
What do you mean by "detuned?"
Since the sprinter van is bigger wouldn't they want to tune to further as to get more power out of the motor?
Old Jan 25, 2013 | 10:48 AM
houseofdiesel's Avatar
2008 R320 CDI, 2006 smart fortwo cabrio, 1983 240D, 1982 300SD, 1980 300SD
There are differences to the trim of the engines, meaning turbos, intakes and exhaust manifolds etc. I think the block and heads are similar, however there maybe different options that change the block on sprinters like PTO etcs. No really positive. Jeep Grand Cherokee has the same engine but also different, only one air intake tube/air filter and different set ups. Detuned engines are to protect the lifespan of the engine and maybe improve emissions. Sprinters are going to be heavily loaded and tow, so the hp and torque is down slightly so they can run at full throttle and still last. The turbos for sure are unique to each application, slight trim differences. Belt setups are different between them too.
They tune these engines to the near maximum for heat and power, there is not alot left to get out them as evidenced by the aftermarket ecu flashes (10% more power, not 25 or more like other diesels).
Old Jan 25, 2013 | 08:15 PM
DubVBenz's Avatar
No, they sell different levels of the same van with the same motor at different tunes. It's the same thing as a W211 E280, E300 and E320 all having an OM642 motor. They can sell the E320 for more because it's setup to produce more power.
Old Jan 25, 2013 | 09:30 PM
isstay's Avatar
I do think that the engine and turbo are same (low cost and modular setup) but intake, ECU tune (amount of fuel delivered, timing) are different thus different power/torque levels depend on configuration (transmission/axle, 4Matic). For example W212 300 and 350 CDI use same engine 2,987 cc but they make are making from 204 to 265 hp and respectively 370 to 460 lb-ft.
Old Jan 26, 2013 | 03:45 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Do you have the OM 646 4 cylinder diesel engine of 2.148 litre capacity used in any vehicles in the USA ?
Old Jan 26, 2013 | 11:50 AM
isstay's Avatar
It is comming w/new GLK and the new C class, also there is a rumor to put it in Sprinter.
Old Jan 26, 2013 | 10:02 PM
MBtech1098's Avatar
10 speed bicycle
The 4 cylinder that will be in the GLK is the OM651. The Sprinter 4 cylinder will come to the US.
Old Apr 25, 2013 | 08:54 AM
CathalGildea's Avatar
2008 S320 L CDI
Hello,
First Post,
I've been looking everywhere for a post like this. I've been trying to find the answer if al OM642 engines are the same.
I have a 2008 S320 CDI (European car, Ireland)
Will any Om642 engine fit my car and my transmission?
My engine code is OM642.930 but cant find a replacement engine from an S-Class, only OM642.920 spares.
I know the sump pan is different and the engine cover but is there anything else?
Will it work?
Cathal
Old Apr 25, 2013 | 07:42 PM
DubVBenz's Avatar
I know the by the time the W221 received the diesel in the states, it was using a twin scroll turbo producing around 265HP, so I think there's multiple versions floating around out there... May want to check on peachparts.com or the UK equivalent of epc , I think this might be a place to start: http://www2.mercedes-benz.co.uk/cont...tion.0002.html.
There's also a UK MB forum which probably has some better information than us.
Old Apr 26, 2013 | 04:36 AM
2008 S320 L CDI
I've asked in UK forums but no one can give me a 100% answer. I asked an engine builder aswel and he said, crank, pistons, and cylinder head had the same part numbers so I assume it should just drop in if they use the same transmission.
