black smoke when accelerate
I told dealer, they said it was because the air filter was block, and replaced a new one. But still the same!!
Do anyone know what happen?
Kevin
You do not say where you come from as countries have different environmental pollution rules. Do you have a DPF?.
My 2007/2008 220CDI creates black smoke on hard acceleration especially from low revs when the turbo charger is caught out & has to spin up to supply the correct fuel air ratio.I do not have a Diesel Particulate Filter . Engines with DPF's fitted would release less/no carbon under heavy acceleration.
My previous car, a 1994 Peugeot diesel would completely black out the road if the turbo was caught out.
So if you do not have a DPF I would say that it is normal but not the way to drive on a regular basis.
John.
If you do not have one think yourself lucky because of the possibility of it blocking at some stage . It also has a regenerative process which is complicated when only short trips are made ie not enough heat produced in the exhaust to burn off the carbon.
Drive conservatively & you will have no smoke ....easy ....
I think it had sat for a long while, and it wasn't warm at all when I put it on an entrance ramp and stomped on the pedal.
In 25,000 miles, I've never seen it again.
