Another 2010 ML350 Bluetec engine seized
I haven't seen oil that bad since they invented oil pumps and detergent motor oil! Before that, using putty knives to scrape out the sludge was a regular procedure.
Looks like a soot or coking problem.
I wonder if the electric Turbo oil pump, which continues to circulate oil after hot shut-down, is the culprit.
I will steer away from Diesel engines period (not that gas engines are any better)
That said.. All cars have a problem or another. It is just that diesel engines add another WORRY angle
I think this topic covers extreme situation, who is not investigated to the end.
What does not change the fact, that modern diesels are very sensitive instruments and letting mechanics to service them without supervising can lead to disaster.
should I buy that 2012 E350 bluetec (sharp black on Black). Opinions are welcome
It's probably the wrong car for you, unless you get a CPO and sell it when the warranty expires.
The 4-banger has easy aces to everything and I just swapped V6 engine. Took me 2 days on V6 to disconnect the maze of sensors that you can't even see. Check pricing for oil cooler replacement on V6.
It is NOT Your Fault. Same happened to me....
I own a 2011 GL 350 Bluetec with 137K miles on it.
Engine seized and is Gone.
the Mercedes Bluetec Diesel engine is 100% a Lemon.
just wait till all the Sprinter Vans Start Locking up....
its a matter of time
i hope Mercedes Pays for their lies.
the Mercedes Bluetec Diesel engine is Horrible Design.
It Recirculates Exhaust gases into Engine oil causing Sludge and eventually Seizure.
NEVER buy a Mercedes Bluetec Diesel engine unless you want to lose your MONEY and Sanity.
i lost 19000 dollars on a well maintainee SUV.
mercedes Answer as can be seen is Blame the owners of their cars instead of the HORRIBLE engineers they have!!!
It is not owners responsibility to be engineers for Mercedes.
who will Pay the 19,000 Dollars i lost???
i have 2 children and my wife in school.
I Hope to God that Mercedes is Sued and Ownersbluke me, KRD2023 and others who Lost money recover their Money.
All those Fedex Vans running Sprinter Bluetec will soon lock up....it DOES NOT MATTER interval of Oil change...No Engine can be this POORLY Designed.
ford, GM, etc all make diesels with their issues but unless it is deliberate, never heard of Engine Seized by Sludge even following their recommendations.
look up on Youtube "Mercedes Bluetec Sludged engine"
two rebuilders in Canada replace a seized up Bluetec engine. Again Same MODUS OPERANDI by Liers at Mercedes....you did not change oil often or even more OUTRAGEOUS wrong oil.....Look at Video in middle where they open the Engine....litreally the inside looks like someone got OIL TAR FROM THE SAND PITS AND IS CAKED LIKE CEMENT....LOOK AT IT....YOU WILL BE SCHOCKED AT INSIDE OF ENGINE....
owner SWEARS THEY CHANGED OIL REGULARY.
MERCEDES will one day be Sued for all this!!!.
NEVER BUY A MERCEDES BLUETEC ENGINE!!@
note the CDI ENGINE NEVER SEIZES With regular oil changes...but they stopped it in 2008 to comply with Emmision Regulations!!!
It is my belief that Benz USA needs to either shorten drain intervals or switch to the high ash 229.5 engine oil with it's hefty additive treat & accept that Cats & Regen units won't last quite as long.
Mike T.
https://www.motor.com/magazine-summa...s-august-2018/
if that is case then Mercedes WILL BE SUED for DELIBERATELY Supplying the US with "Obslete " Engines...
no one is Forcing them to supply these Engines....They market and Sell them in US with ZERO WARNINGS that they are Obslete for US Fuels.
more Evidence of Mercedes Corruption.
never BUY Mercedes Bluetec Diesel engine Ever!!!
wait till Fedex and All Sprinter Vans and RVs etc....Lock up...Class Action Lawsuit ...God Willing!!
Those threads here made me taking apart my OM642 engine after it suck some water and bend the rod. This is DPF equipped model, but no AddBlue
At 180,000 miles there was no smallest sign of sludge in it and beside intake & EGR buildups, I don't see why the engine should not make million miles. It was dealer-serviced for 160k miles and I serviced it for last 20 k miles using FSS recommendations.
But now I am extra careful with oils and buy Motul at autohouse.
All things considered, it's clear by now that MBUSA should have taken accountability for known sludging issues with the OM642 engine operating in U.S. markets.
however. The whole game of Mercedes seems obvious.....obfiscate, confuse, mixup,....etc..
result is same .....The Om642 is Cdi.engine and is one of best diesel engines internally and i Still own one and engine is clear of any sludge......in 2009 they switched to AdBlue and changed the engine somehow where it SLUDGES like no other engine does!!! Dodge, Ford, GM, cummins, etc....wirh regular oil changes do NOT sludge and lock up needing 20,000 replace cost on a 70,000 suv.
krd2023 did all his maintenance at MB dealer, and so is other poster, and so did the person in youtube video in Canada and so did I,.....A LEMON IS A LEMON.....Just because it may work for 80k or 130k and then with NO WARNING just Lockup....
mercedes will NEVER own up unless the Cry of Lawyers is loud and it wont be until Enough of these engines are driven in USA and lockup despite very good maintenance.
NEVER BUY MERCEDES BLUETEC DIESEL ENGINES
last good diesel engine made by MB in 2008 was the CDI diesel!!
i still own 2008 CDI and Gasoline S class....but trust in MB is gone!!
here is the Youtube Video which you Will See what we mean by Sludge.
2010 GL 350 Bluetec with AdBlue emmisions.
Car had 50,000 Km or about 30k miles.....Almost Brand NEW.
Owner says he Did Oil Changes at MB dealer.
Even if not, this is OUTRAGEOUS from Mercedes Engineering.
Look at Video and I Want to see Who After seeing this would put their Hard earned Sweat money into this pile of Garbage Mercedes Bluetec engine.....Look at minut 3:14 and 3:46.
Watch and listen to Whole Video.....Even the Rebuilders are Schocked by what they saw
Watch "2010 Mercedes-Benz GL350 – Engine Replacement" on YouTube
https://youtu.be/R-h77NcOcNQ
BTW ~ I posted pictures of the sludge early on this forum.
Venting & performing on a forum achieves nothing even though Benz does monitor. Time & time again a quiet & dignified approach to MBUSA preferably with the dealer in support has achieved a satisfactory conclusion for all. e.g. the early M272/273 balance shaft sprocket issue.
At the beginning of the you tube video it’s made mention the oil looked like never had been changed. What would you expect. Also it would not suprise me if the car had been brought in for a service that was not done. I don’t trust the dealerships or many mechanics for that manner. I have seen too much incompetence. I wish I could do more myself but can’t so.
I do however see these engine components failing from the substandard oils being used causing premature wear to save the dpf and have better feud economy. As well as the dpf itself producing much more heat on the engine during regen cycles as well as just pure unneeded back pressure. Not to mention the mess made by the mixture of the egr and ccv in the intake. But sludge should not be an issue period.
Btw the dpf, egr and oil problems are an easy fix. Knowing what I know now I wish I had taken care of with a tune when I first bought my 08 with 72k miles. I did around 130k and currently am over 170k
