Diesel smell in cabin
Old May 1, 2016 | 06:09 AM
pmaccoventry's Avatar
cclass 220cdi
I have a C class cdi 220 coupe and I'm getting diesel smell(unburnt) in the cabin. This happens only when the heating/air con is in use. There are no obvious signs of a diesel leak in the engine compartment. Has anyone experienced this problem and resolved it?
pmac
Old May 1, 2016 | 09:33 AM
marc hanna's Avatar
2023 GLK250, 1987 560SL
You may have a leaking injector seal. Check that first - very common. With the engine running look under the hood to see if there is a jet of air coming from the cylinder head anywhere.
Old May 2, 2016 | 05:05 AM
cclass 220cdi
Thanks Marc, I will investigate asap
Old May 4, 2016 | 12:57 AM
Glyn M Ruck's Avatar
Super Moderator
The other area to check are on the 2 sealing rings on the saddle fuel tank for the level sensors & pump. Under lower squab of rear seat under 2 cover plates. They sometimes leak!
Old May 4, 2016 | 08:53 AM
Micah / AF1 Rac's Avatar
W211 e320 CDI
My car has the tank sender sealing issue on hot days or very cold days if parked overnight with a very full tank. Up front I've had leaks at fuel/water contamination sensor and each fuel filter hose at different times, 176,000 miles and injectors seals are still dry on mine.
Old May 4, 2016 | 11:59 AM
Super Moderator
Yup W211 was well known for it but other models too & they have improved the seals & method. Early units were like jar tops!
Old May 6, 2016 | 08:06 AM
cclass 220cdi
Thanks to all who have replied to my question. I still haven't found the cause of the problem. The air temperature has gone up to 14 to 16c from 4 to 8c this week and there is now no smell in cabin when using air con so I will home in on the heater.
