Need advice for replacing broken plastic "brace" for throttle linkage on ol' OM603
My '87 is having a hiccup. The accelerator pedal is going straight to the floor after startup. Apparently the Linkages fell loose atop the Injection-Pump and conveniently under the intake-manifold. I do not want to pull off the manifold to replace the piece, however if replacing the broken plastic piece with a new one is the only option, and required removing the manifold...well then what choice do I have? That brittle little B$%# broke on me when I was out on the trails with my dog, so I had to use handy-dandy zip-ties to rig something up. Keeping form and function in mind, I was able to rig up a few systems that seemed good to the touch but had no result at the pedal. After an hr I found something that was able to get me to a low rpm. With mostly country roads between me and my home, I was able to work the gearbox and turbo to get up to 4th eventually and get home safe. Now Id like to fix the problem. I have a 92 with the 2.5l turbo-Diesel but the assembly of the throttle with the IP is a completely different set up.
If you have an OM603, please look between the 5th and 6th cylinders and at the bracket and tell me your two-sense.
Reason: pics
