OM642 EGR/intake cleaning
Old May 23, 2018 | 04:51 PM
DanD.'s Avatar
2018 GLC 4MATIC
Originally Posted by peter2772000
Stoopid simple.
https://www.youtube.com/results?sear....20+EGR+Coking
Sorry, he'd included that in the email.
I guess Im more stupid than I thought, but I can't find any video on how to do it on OM642.
I see how to clean turbo but not ERG.
Old May 23, 2018 | 06:19 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Sorry Dan, I'm clueless.
Old May 23, 2018 | 09:10 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Again. I'm curious where Stephen taps in to introduce the cleaner.
for those that have a dirty throttle body, I would spray via the port designated with an orange arrow in the attached image. As you have to remove the sensor temporarily, this will throw codes so you'll have to clear them after you're done spraying Liqui Moly or BG245 or whatever else that may work.
I should add that this is an image of 2007 W211 OM642. Your setup may be different.
Old May 24, 2018 | 09:55 PM
DanD.'s Avatar
2018 GLC 4MATIC
[quote=GoodByeHonda]Again. I'm curious where Stephen taps in to introduce the cleaner.
for those that have a dirty throttle body, I would spray via the port designated with an orange arrow in the attached image. As you have to remove the sensor temporarily, this will throw codes so you'll have to clear ....]
Is this the same spot? Please see attached pic.
Its a EGR temp sensor part # A0071538128
OM642 EGR/intake cleaning-photo849.jpg
https://www.getmercedesparts.com/oem...sor-0009054205
Old May 24, 2018 | 10:49 PM
That looks like an excellent spot! That must be the access point Mr. Stephen is referring to. This places the nozzle at the point where the left and the right intake manifolds will get exposed to the cleaning solution.
My 2007 w211 Om642 does not have that sensor. Looking at my setup, best way is to remove the "muffler" which is located just above the throttle body and run the nozzle just before the 2 manifold openings.
Old May 25, 2018 | 12:19 AM
DanD.'s Avatar
2018 GLC 4MATIC
Had some conversation with people who worked on Audi's a BMW diesels. Their opinion on using spray is hell NO.
All that buildup will go through the engine, it might made very big damage.
The right way is to take thar pipe and replace with new. Pipe is about $40.
Old May 25, 2018 | 02:13 PM
  #32
What sort of damage have they mentioned?
Old May 25, 2018 | 05:49 PM
  #33
DanD.'s Avatar
2018 GLC 4MATIC
They both dos't like an idea of sending all this buildup back through the engine. Especially it might damage valves.
They said, want it to be clean, take if off and clean or put new in.
Old May 25, 2018 | 08:58 PM
  #34
I personally am not concerned about this "soft" sludge affecting metal interior parts. I'm more concerned with DPF so I'm thinking of perhaps temporarily disconnecting exhaust during Liqui Moly application.
Old Jul 1, 2018 | 01:12 PM
  #35
Shizzell's Avatar
2008 ML 320 CDI
@GoodByeHonda Could you send the part numbers for the gaskets that you'll need to manually clean this pipe? It'd be much appreciated, thanks.
Also, from what I'm understanding, it's just 3 bolts on the one side to remove the pipe from the engine?
Old Jul 1, 2018 | 11:12 PM
  #36
The two gaskets that I'm showing above with a penny are for 2007 E320:
A 642 141 00 80
A 026 997 43 48
Old Nov 2, 2019 | 08:54 PM
  #37
007_e350's Avatar
X166 gls450 2017
I’d put a block plate and get EGR coded out... no more BS
Old Nov 3, 2019 | 06:23 AM
  #38
I had a tune downloaded which deactivated the EGR among other things. I had the DPF eliminated and the DEF deactivated. Hopefully I'll have relative dependability and no worries about EGR blockage etc,
Old Nov 8, 2019 | 10:11 PM
  #39
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Can you share details about tune?
Old Nov 20, 2019 | 07:56 AM
  #40
kde's Avatar
kde
2011 GL350
Funny, I just received an email today from Mr Stephen himself, along with two attachments for the intake/EGR cleaner.
i can’t locate the Liqui Moly Diesel Intake clearner (5168) anywhere in the US. Just reached out to Liqui Moly. Any idea where I can get a can?
Old Nov 20, 2019 | 11:59 AM
  #41
kajtek1's Avatar
1922 Ford Model T / no OBD
You need to open your horizons.
Russian friends will ship it to you.
https://www.ebay.com/sch/i.html?_fro...arner&_sacat=0
Old Nov 22, 2019 | 05:55 PM
  #42
Bern6389's Avatar
2014 GL350 Bluetec X166
amazon has them as well.
Old Oct 2, 2020 | 03:47 PM
  #43
Timmer55's Avatar
Sprinter 3500
EGR Bulletin...
Looks like MB came out with a bulletin advising service to clean the short Egr pipe(front of the engine refered to as egr admission hose) every 40k miles. What I'm looking for is a way to tap into the intake system of a running engine (so without taking it apart) that I could spray in the cleaner at a pressure which would end up as a nice gush of a mist.
Has any one done it? What's the ideal spot to tap in? Ideally I'd like to get rid of the EGR system as I see it as the main culprit of diesel engine problems but for now, I'll remove the egr admission pipe and clean it following with a spray of the cleaner.
Does the MB bulletin specific engines and years? I have a 2008 3.0 OM642 v-6 and occasionally receive check engine errors that reference EGR. However, I don’t have any typical bad EGR symptoms.
Old Nov 27, 2020 | 12:06 AM
  #44
Ubbenzforum's Avatar
E350
Can you share the tune? Or where to get it. Also how to apply the update. I have a 2011 om642 W212.
Old Nov 27, 2020 | 08:36 AM
  #45
Contact Malone Tuning and ask them for a shop near you.
Old Nov 27, 2020 | 10:12 AM
  #46
kajtek1's Avatar
Wasn't it Malone put out of business by EPA ?
Old Apr 14, 2021 | 04:04 PM
  #47
B34chBum's Avatar
R320, Astro, JSW, ST4
Green Diesel Engineering (GDE), was. They were out of Michigan I think.
I contacted Keith the year before the stuff hit the fan, but I didn't pull the trigger.
Malone is out of Vancouver BC area, still around I guess is a jurisdictional thing.
Old Apr 14, 2021 | 05:02 PM
  #48
Just checked, Malone's site is still live. Regardless, Green Diesel had nothing for my truck
Old Apr 14, 2021 | 05:29 PM
  #49
kajtek1's Avatar
It is EPA in USA who is chasing the cheating. Sounds like Canada doesn't have similar agency, or just doesn't care.
Old Apr 16, 2023 | 08:31 AM
  #50
WaarrEagle's Avatar
2009 E320 Bluetec
I just removed this pipe on my 2009 E320 Bluetec. To confirm, yes, only 3 bolts on the throttle body side to loosen the whole pipe. It then has a compression fitting over the o-ring on the other side, no bolt. The parts numbers listed worked for my E-320. The o-ring on the inlet side of the pipe took me an hour fiddling with different picks to get off. Otherwise the job is pretty easy.
