E320 V6 cdi Tuning (T-Rex)
Old Oct 30, 2018 | 04:06 PM
hartge6's Avatar
w211 - w210 - Vito
The cylinder head is slowly ready .. swirl flaps delete.. and air intake porting and poilsh to cylinder head diameter..
Old Nov 11, 2018 | 02:02 PM
hartge6's Avatar
w211 - w210 - Vito
And inside the car..
Old Nov 11, 2018 | 02:15 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Looking awesome bud!
Old Nov 11, 2018 | 03:49 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Why did you put incomplete engine into car? Now connecting the wires is going to be a nightmare.
Old Nov 12, 2018 | 02:26 PM
hartge6's Avatar
w211 - w210 - Vito
Because there are still many mods ...they are not ready yet ... Connecting no problem .... bat yes simple case it's completely simpler..
Old Dec 18, 2018 | 02:46 PM
hartge6's Avatar
w211 - w210 - Vito
And again a little upgrade....I see its inner diameter too small (3 cylinder 18-20mm)
so I made a bigger one ... it will be better for the larger turbo ... Yeah and EGR off..
Old Dec 19, 2018 | 09:15 AM
  #32
Mods made at your leisure are the best. Not pressed for time, your wife isn't pestering you to get the work over with because she's fed up of sharing her car with you.
The best!!!
Old Dec 19, 2018 | 02:05 PM
  #33
hartge6's Avatar
w211 - w210 - Vito
[QUOTE = peter2772000; 7633804] A szabadidőn belül készített modok a legjobbak. Nem nyomják az időt, a feleséged nem gúnyolja meg a munkát, mert elakadt tőle, hogy megosztja veled a kocsiját.
A legjobb !!! [/ quote]
Köszönöm .... igen sajnos sok idő múlásával ... de szeretem csinálni ... Igen, a feleségem szereti a kocsikat ... így bocsáss meg az időt töltött az autó ..
Old Dec 19, 2018 | 04:05 PM
  #34
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Nice work! It's a work in progress but should be awesome when youre done!
Nem értem 😥😔
Lucky you that your wife is supportive! 😝
Old Dec 19, 2018 | 04:15 PM
  #35
Szerencsés fickó!!!!
Old Jan 27, 2019 | 05:43 AM
  #36
Any developments?
Old Jan 27, 2019 | 01:04 PM
  #37
Micah / AF1 Rac's Avatar
W211 e320 CDI
Yeah, curious as well. Have opportunity to pick up an 07 OM642 e320 for $2k running....similar but not same mod process would start ASAP!
Old Jan 29, 2019 | 02:55 PM
  #38
hartge6's Avatar
w211 - w210 - Vito
[QUOTE = peter2772000; 7.665.296] Bármilyen fejlesztések? [/ QUOTE]
I have a lot of work..but I'm moving slowly.. Now little turbo upgrade orig gt 2056v*exchange gtb 2060vklr ball bearing .. (later*it will continue to build)*
Old Feb 1, 2019 | 12:23 AM
  #39
OM617.95's Avatar
1982 300D
Diesels do not need lower compression for increased performance. There are many competition diesels running 100+psi boost on stock compression ratio. Whats needed is stronger headgasket and stronger head bolts (studs).
Old Feb 1, 2019 | 08:45 AM
  #40
W211 e320 CDI
Lowering compression is common too, a buddy does tractor pull diesel big rig motors, his dyno maxes out (old water brake style) around 2500 bhp. It’s fascinating to watch them light off a test motor, some are running triple compound external compressors and nitrous and/or propane. They have removable ports in eaxhaust manifold similar to wideband ports, they torch heat 2-3 exhaust valves to act as mega glow plugs. Peak boost is over 200 psi once fully spooled. I know it’s redneck as ****, but if you ever a get a chance to go see live in person big diesel tractor pulls, I seriously hope you will. Even the Detroit diesel 2MV12 (may have nomenclature wrong) I raced (pitted across from us during KTM/Ducati Team days) with at bikes peak hill climb (PPIH) had reduced compression pistons from stock though larger bores, V12 layout with a pair of roots type blowers and 4 plus turbos depending on which year in addition to being a valves two stroke diesel. This was even done at 10k feet MSL because they go better power from charge cooled boost than higher compression. I’ll see if I can find a video of that thing, one of the sickest engine sounds ever to be created by direct oil injection!
these mega motors are fascinating to watch on the staging line. Set brakes or Torque Converter...push pedal down slowly, a solid black column of smoke rises out the top, as compound turbo sections each begin to spool that column of smoke goes from solid black to opaque and then when big final charger is up to speed, clear heat distorted air and sometimes a little bit of blue fire out top of stacks...then release brakes, and drop hammer. I’ve watched tractor pull motors make over 300 psi boost but only on 6-8:1 compression pistons. I will pick up a spare blown piston next time I visit dudes shop, he owns an airport west of Houston so flying in to watch a test or two (open air dyno) is only a 45 minute hop from my home airport. Imagine a LONG skirt typical truck diesel piston. You know how piston crown has flat squish are then a dropped center with a conical raised section. Imagine this but with say only 10mm squish band width, combustion pocket recessed to just safely above wrist pin, still a bit of a strengthening hump on bottom of chamber, heads while ported look stock-ish from bottom or fire deck side.
Lemme see if I can find a video of that PPIH race truck with the V12....if I do listen through a decent headset and volume up, in person it sounds amazing!
here is Banks engineering Detroit diesel V12, it’s a compound setup with perhaps only one turbo (giant) and 3 roots blowers
[VIDEO]
[\VIDEO]
just YouTube “PPIHC diesel truck”
Old Feb 2, 2019 | 02:28 PM
  #41
hartge6's Avatar
w211 - w210 - Vito
[QUOTE = OM617.95; 7669742] A dízelek nem igényelnek kisebb tömörítést a nagyobb teljesítmény érdekében. Számos verseny-dízel van, amely 100 + psi-es növekedést mutat az állomány tömörítési arányán. Mi szükség van, az erősebb headgasket és erősebb csavarok (szegecsekkel). [/ QUOTE]
If you are so sure that*there is no need..you can show me then.. 4-500 hp* *3.0 V6 cdi ..factory interior...* * *(There are no stronger parts)
diesel and diesel engine*between*there are many differences...*
Old Feb 11, 2019 | 11:27 AM
  #42
KenYed's Avatar
X164 GL 320 CDI
Thumbs up
Thats so crazy!! I lol'd at torch heating the valves!!
Amazing description Thanks for sharing ^_^
Old Feb 13, 2019 | 11:26 AM
  #43
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Holy ****, this douchebag is back under a new name.
Old Feb 17, 2019 | 10:58 AM
  #44
W211 e320 CDI
Ok, the diesel forum has been seriously low traffic lately....chat it up folks.
Old Feb 23, 2019 | 02:43 PM
  #45
hartge6's Avatar
w211 - w210 - Vito
Of course, many say I'm a fool..but no one has done this yet..I will do it..:zoomolás:
2200 bar injector ... can be loaded with some modifications...
Old Feb 23, 2019 | 05:20 PM
  #46
W211 e320 CDI
I love it when people make something work that’s not supposed to!
Old Feb 24, 2019 | 01:41 AM
  #47
OM617.95's Avatar
1982 300D
I'm sorry you, the real douchebag here, never left.
Old Apr 19, 2019 | 02:42 PM
  #48
hartge6's Avatar
w211 - w210 - Vito
But, unfortunately, it was needed! 6 out of 4 leaked.. so it must be replaced.. and why this? more rail pressure ..better spraying..no smoke.. no smoke ? more quantities.. = more power.. with minimal smoke
1600 bar injectors distorted spraying 1800-2000 bar over ...
Old Apr 19, 2019 | 02:47 PM
  #49
hartge6's Avatar
w211 - w210 - Vito
If you can intelligently speak,then do it..bat no, then do not write... thanks..
Old Apr 20, 2019 | 01:52 PM
  #50
hartge6's Avatar
w211 - w210 - Vito
Bigger pump.. CP3 L110 (420 cdi ) bat not plug and play ...but it can be solved...
