Is this too much blowby? Om642
Old Mar 8, 2019 | 02:02 PM
Towmater's Avatar
Ml350 bluetec
I know these engines are looser than snot, but it seems like a lot. At operating temprature there is enough force to the air to hold a 2 sheets of paper completely off the hose.
ML 350 bluetec om642 178k tuned no dpf
I wonder if somehow the egr is stuck open? What do you all think?
https://youtu.be/uoJt1HmQn3A
Old Mar 8, 2019 | 03:15 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I always do the test on oil fill hole. All my diesels will not blow single napkin.
Old Mar 9, 2019 | 03:37 PM
Towmater's Avatar
Ml350 bluetec
On this diesel it flings oil out the oil fill when the cap is removed.
Old Mar 9, 2019 | 04:27 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Seems like an oil analysis would be money well spent.
Old Mar 9, 2019 | 08:25 PM
kajtek1's Avatar
Not when you put napkin over it.
When you have excessive blowby, compression test or smoothness test is in order.
Old Mar 11, 2019 | 03:37 PM
Anthony Porta's Avatar
Ml350
Thank you, who do you recommend?
Old Mar 11, 2019 | 04:54 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Blackstone Labs is the one I hear about the most, I've only dealt with them once myself.
Old Mar 11, 2019 | 05:17 PM
DanD.'s Avatar
2018 GLC 4MATIC
Blackstone, used them like 6 times for different cars. Like them.
Old Mar 11, 2019 | 05:52 PM
kajtek1's Avatar
Blackstone will send you sample containers with prepaid shipping for sending them back. You can order on the net, or call them.
They are not very fast, so you have to be patient with them.
Old Apr 21, 2019 | 03:37 PM
Towmater's Avatar
Ml350 bluetec
Oil report in. oddly enough it looks good.
Old Apr 22, 2019 | 12:00 AM
kajtek1's Avatar
What oil did you use? Doesn't look like synthetic.
It is good report, what you want?
Old May 21, 2019 | 07:42 PM
Towmater's Avatar
Ml350 bluetec
To know why I use a quart every 500 miles. more when cold and why it smokes at high rpm...
Old May 23, 2019 | 10:29 PM
Towmater's Avatar
Ml350 bluetec
Still digging. Found this lovely crud in the egr pipe.
Old Jun 4, 2019 | 11:42 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Replace PCV valve and install oil catch can. This should help.
Old Jun 4, 2019 | 11:51 PM
Towmater's Avatar
Ml350 bluetec
I already have a catch can. Do you have the pcv part number by chance?
Old Jun 5, 2019 | 01:41 AM
artim808's Avatar
I think this is the one for your car.
https://www.fcpeuro.com/products/mer...mer-6420102391
How you installed catch can? Did you cut the hose from pcv valve to turbo intake?
Old Jun 5, 2019 | 05:49 PM
Towmater's Avatar
Ml350 bluetec
Yup.
