I'm I in trouble?!
Old Mar 23, 2019 | 03:29 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Most probably.
Send me your ECM, I'll drop it off at the shop near my place and have them do the deletes. Prolly cost you around $600, if I remember correctly. You'd have to find someone local to do the DPF bypass, or simply drive it 'till it plugs up
Old Mar 23, 2019 | 04:02 PM
albanian111's Avatar
2014 e250 bluetec
Originally Posted by peter2772000
Most probably.
Are you in Canada ?
Old Mar 23, 2019 | 08:47 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
My DPF was having mechanical damage, so I chiseled the insides out.
Took me about 1 hr on the edge of garbage can as I don't have good work bench.
Removal and installation is about 1 hr each when you have lift.
Somebody was posting that tuner in CA does deletes for $100 each, but that was still with some mishaps.
Old Mar 23, 2019 | 09:01 PM
harm9's Avatar
2014 E250 Bluetec
Wink
http://ecuprogram.com/mercedes-benz
Check these guys out they are in Alberta . JKENNY !
Old Mar 23, 2019 | 09:13 PM
harm9's Avatar
2014 E250 Bluetec
Originally Posted by albanian111
Are you in Canada ?
how many km on your car? Is it a rebuilt ?
Old Mar 23, 2019 | 09:28 PM
harm9's Avatar
2014 E250 Bluetec
Are you in Canada ?
Have you read your "Service and Warranty" Booklet, specifically the 7 page section that deals with "Emission Performance Warranty" ?
On the 6th or 7th page of this section, it specifically mentions that the DPF is covered for "8 years or 130,000 km, whichever comes first". Thus , there is no need for an Extended Warranty to cover the DPF.
Old Mar 24, 2019 | 04:10 PM
  #32
Are you in Canada ?
Montreal
Old Mar 27, 2019 | 09:46 AM
  #33
107123210's Avatar
This is correct for DPF, Catalysts and a few other items. But not for Adblue system and some sensors. I posted just what is covered elsewhere, but could find it with some time. Is your car still within the 8years/130k km limit?
There has been discussion elsewhere of Bluetec delete. One guy I recall was from Calgary in GLK250 forum.
Here: https://mbworld.org/forums/glk-class...-disabled.html
I never had any problems with my Bluetec diesel, but only drove it 50k km! Others have also had good luck. Everything can be fixed, but the DPF/Bluetec/Sensors are very expensive to replace.
My brother owns an E250 CDI in Africa . They don't have low sulphur fuel everywhere there, so cars have a different engine. Or maybe similar engine without Bluetec? Seems there would be a market for those engines here!
https://www.cars.co.za/motoring_news...reviewed/9594/
