Mobil 1 ESP 5-W30
Old Apr 17, 2019 | 11:28 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
Mobil 1 ESP 5-W30
I'm having trouble finding this oil in my city. I tried to make an appointment to get it changed and the shop said they couldn't find it. They called the local MB dealer who said to use regular Mobil 1. I can't believe it.
Old Apr 17, 2019 | 02:09 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Just saved one engine!
Old Apr 17, 2019 | 03:04 PM
gkgeiger's Avatar
Found locally, Summit Racing. Didn't even think of them, I'm a Pro Shop cust. paid $10.05 Qt. I think that's a fair price.
Old Apr 17, 2019 | 03:14 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Fcp euro also ships Liqui molly oil for cheaper if you want to try.
229.51 and 229.52
Old Apr 17, 2019 | 03:24 PM
Gazwould's Avatar
S204 C250 CDI Sport
Lol , no understanding of oil !
Old Apr 17, 2019 | 04:52 PM
Higher ash content causes increased frequency of regen cycles causing increased motor oil dilution and hence loss of lubrication. No?
Old Apr 17, 2019 | 05:37 PM
lkchris's Avatar
'10 CL550, '12 GL550
Essentially, specification 229.51 is dead ... replaced by 229.52.
By definition, 229.52 will be 5W-30. It's an FA-4 product
To explain, the following is extracted from https://en.wikipedia.org/wiki/Motor_oil
The current diesel engine service categories are API CK-4, CJ-4, CI-4 PLUS, CI-4, CH-4, and FA-4. The previous service categories such as API CC or CD are obsolete. API solved problems with API CI-4 by creating a separate API CI-4 PLUS category that contains some additional requirements – this marking is located in the lower portion of the API Service Symbol "Donut".
API CK-4 and FA-4 have been introduced for 2017 model American engines.[13] API CK-4 is backward compatible that means API CK-4 oils are assumed to provide superior performance to oils made to previous categories and could be used without problems in all previous model engines (but see Ford below).
API FA-4 oils are different (that is why API decided to start a new group in addition to API Sx and API Cx). API FA-4 oils are formulated for enhanced fuel economy (presented as reduced greenhouse gas emission). To achieve that, they are SAE xW-30 oils blended to a high temperature high shear viscosity from 2.9 cP to 3.2 cP. They are not suitable for all engines thus their use depends on the decision of each engine manufacturer. They cannot be used with diesel fuel containing more than 15 ppm sulfur.
Cummins reacted to the introduction of API CK-4 and API FA-4 by issuing its CES 20086 list of API CK-4 registered oils[14] and CES 20087 list of API FA-4 registered oils.[15] Valvoline oils are preferred.
Ford does not recommend API CK-4 or FA-4 oils in its diesel engines.
Your Mercedes dealer only stocks 229.52
Old Apr 17, 2019 | 07:14 PM
Gazwould's Avatar
S204 C250 CDI Sport
Only if it were that simple , for sure the 229.51 &. 52 are lower sulphated ash but Mobil 1 5W30 ESP Formula is a C2 .
It's not like we're comparing a dpf low saps oil to non dpf with high ZDDP content .
Many more factors at play like how much the ECU software dictates egr operation thus more incomplete combustion - soot .
And how fit the thermostat and CTS is for warm up times and accurate temperature sensor readings for accurate fueling ratios .
