Weird occasional jerking W204 C220cdi manual
Old May 9, 2019 | 01:27 AM
jukej's Avatar
W204 c200
Weird jerking C220cdi
Hello all!
Car is 2009 C200cdi manual estate.
I've had this odd issue for a while now. Occasionally there are odd slight jerking when driving. Not so big difference but noticeable anyhow. Starting the car or anything wont help. On next day it's probably gone.
Old May 10, 2019 | 02:46 PM
nutzu_gotgame's Avatar
C220 bluetec manual w205
I notice sometimes some similar in second gear if is somewhere between 1100-1600rpm. Not always. Usually in city driving. I did not gave it too much attention because i thought that is just under power. Is true that's a strange behavior. I am not sure if is something "normal" or not. This happens rarely. I usually change next gear when I'm over 2300rpm. Also on manual om651
Ps: i had similar behavior on the previous car that was also a diesel-manual gearbox
Old May 12, 2019 | 03:10 AM
jukej's Avatar
W204 c200
Yeah, that is weird.. Idle is totally normal. Did you ever get any cure for the issue?
Old May 12, 2019 | 04:38 AM
I do not think that has to do with brakes. This happens when the engine is under power curve ( 1000-1500rpm). More likely has to do with injection map, or flywheel. That's my opinion. At least in my case tis is not a issue. Just change gears higher in rpm range. (Over 2300rpm depending of driving conditions)
Old May 14, 2019 | 01:27 AM
jukej's Avatar
W204 c200
In my case it doesn't effect if I'm driving 3000 or 1500 rounds. When the fault is on it's on and I can feel it clearly.
My wild ques is that there is some sensor (throttle pedal etc) which is causing the whole thing. Why I think so; The issue is occasionally, it won't happen every time when I'm driving. In a case of flywheel/injection map it would come every time.
But like I wrote, the oddness is that there are no sign of any faults in error log..
Old May 15, 2019 | 10:42 PM
IBelieve's Avatar
2008 E320 Bluetec
Could it be the torque converter locking up? I think mine does it 2 different levels and it kind of jerks forward.
Old May 16, 2019 | 12:26 AM
jukej's Avatar
W204 c200
In gearbox? Is there that kind of converter when it's manual..?
Old May 16, 2019 | 09:42 PM
IBelieve's Avatar
2008 E320 Bluetec
So sorry, missed it being a manual. No, no torque converter.
Old May 17, 2019 | 10:44 AM
B34chBum's Avatar
R320, Astro, JSW, ST4
troubleshooting
Odd combination (lurching and brake smell).
Isolate which brake(s) may be sticking, suspect only a front caliper would have enough effect to contribute to a drive ability problem.
At 9 years old you may have turbo vanes sticking or the vane ring worn.
Another possibility is a leaking boost host, look for oil and feel for split.
The boost control modulation may make the air pressure flutter, trying to get requested/actual level right when there's a non-catastrophic leak.
Old May 25, 2019 | 02:03 AM
jukej's Avatar
W204 c200
Yes, I’ve tried to feel what would be the warmest disk but no luck yet. They all seems to be very warm and that’s why the smell.
