Adblue Emulator
Old Jun 6, 2019 | 12:00 PM
JGR350BlueTec's Avatar
R350 BlueTec
Adblue Emulator
So it looks like I may need to replace my adblue heater for the third time and I think that I have run out of patients for this system. Has anyone had success with using an Adblue Emulator to bypass all this nonsense?
If so, what product did you use.
Thanks.
Old Jun 6, 2019 | 01:08 PM
Towmater's Avatar
Ml350 bluetec
Yes. I found one a while back. Very hard to get a hold of in the us.
In the long run it's cheaper just to pull your ecu and send it in for a tune. Ideally deleting the dpf and egr.
Alternatively you can buy a metal heater instead of the oe plastic ones which will last longer, but something else in the system is likely to break.
Old Jun 6, 2019 | 03:26 PM
R350 BlueTec
who sells a metal heater? It is actually the level sensor that has quite on me (now twice). I can't even remember why the first one failed.
Any recommendations for eco tune?
Old Jun 6, 2019 | 03:41 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
ECU tunes are done "under the table" so be careful with them.
I send my ECU to London for DPF and DEF delete. The guys generate huge cost on wire transfer, shipping and return shipping alone and when they advertised "3 days turn-over" whole process took like 6 weeks with car on the lift.
Than turned out DEF was not deleted. They ask me to send ECU back, but I did not want to go via the experience again and drive with no DPF but DEF still on.
For me DEF deletion had gaining spare wheel space in mind, but now I just put the wheel in the trunk.
Than there is still a question how much you want to poison yourself and people around your car?
Old Jun 6, 2019 | 06:29 PM
Towmater's Avatar
Ml350 bluetec
I would contact this seller https://xemodex.com/us/complete-def-...kit-by-xemodex they make one for the R350
Towmater's Avatar
Ml350 bluetec
https://malonetuning.com/ecu-tuning/mercedes-smart-cdi
these people for tuning.
Old Oct 8, 2024 | 06:40 AM
TomWast's Avatar
mb actros
Hello, have anyone tried to use adblue emulators from https://adblueemulators.com/ ?
