OM642: New viton oil cooler seals still leaking...or?
Old Jun 30, 2019 | 01:40 PM
Diesel-King's Avatar
R 320 CDI
Hi,
One year ago the MB dealer changed the oil cooler seals to the new purple viton ones, replacing the old orange seals on my R320 cdi.
Unfortunately oil has started leaking again through the lower left engine weep hole.
There is no oil dripping from the turbo air inlet so I am inclined to think the problem is again with the oil cooler seals.
But I have also read that the turbo also has an oil feed (through the turbo pedestal?)
How can I tell if it is the turbo oil feed seals without removing the turbo?
Thanks for your help.
Old Jun 30, 2019 | 05:40 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Those engines also have weaker seals on oil filter housing.
With complexity of the engine, you might want to spend 10 bucks on snake camera that attaches to your android.
Old Jul 1, 2019 | 03:20 AM
R 320 CDI
Thanks for the tip but it's not leaking from the oil filter housing (front of the engine).
Has anyone had leak problems with the viton oil cooler seals?
Old Jul 11, 2019 | 01:32 PM
Luke.Berger's Avatar
Mercedes C320CDI
Hi, i have same problem...did you fix it ?
Old Jul 13, 2019 | 05:28 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
The newer purple seals handle the heat better, but are harder and don't seal as well. Heat is your enemy here.
If the seals are leaking, replace them and lose the belly pan and engine cover in order to mitigate under-hood temps.
Old Jul 15, 2019 | 03:30 AM
kajtek1's Avatar
I sold my 2008 car with OM642 engine, but I used it in 120F heat, while monitoring temperature on climatronic and most of the time it would stay at 80C, while dropping to 78C going downhill. Electric fan would go to high when I park the car with AC on.
Bare in mind, that MY had no DEF, but at 180k miles was not new neither.
Old Jul 15, 2019 | 11:42 AM
Towmater's Avatar
Ml350 bluetec
If you get a blanket you can lay on top of the engine and look straight down the center of the turbo from the top. You'll see the two torx bolts holding the turbo and if you shine a light beside them that will show you if its leaking from the pedestal.
Old Jul 17, 2019 | 10:44 AM
R 320 CDI
No, I still gave the leak although I changed to the purple seals.
Will try to see looking over the turbo if it leaks by the pedestal...will report back....
Old Jul 18, 2019 | 04:56 PM
Mercedes C320CDI
Okay. Thanks
Old Jul 18, 2019 | 04:57 PM
Mercedes C320CDI
Okay. Thanks
Old Jul 29, 2019 | 03:33 PM
Mercedes C320CDI
So did you find a problem?
Old Jul 30, 2019 | 10:47 AM
R 320 CDI
I used an android endoscope camera but could only notice that there is no oil around the front part of the oil cooler (front of engine).....could not see if the rear end of oil cooler had any spilled oil.
I guess I will not advance unless I start removing parts standing in the way....but I'm too lazy for that.
As I see it, oil is still leaking through the new viton oil cooler seals or the turbo pedestal oil seal....can not think of any other cause.
Old Jul 30, 2019 | 04:45 PM
Towmater's Avatar
Ml350 bluetec
So, did you look down by the torx and look at the pedestal?
Towmater's Avatar
Ml350 bluetec
You can also put in some dye.
Old Jul 31, 2019 | 03:39 PM
R 320 CDI
No, not possible unless I remove the air intake and possibly other parts like the fuel filter....will do it when the car is serviced.
Yes will add some dye once I receive it from Ebay.
Old Aug 8, 2019 | 01:54 PM
Mercedes C320CDI
Did you find a problem or no ?
Old Sep 26, 2019 | 10:22 AM
dhurley's Avatar
GL320
722.9 bushing style front pumps often fail and will weep fluid through the bell housing and mimmick the oil cooler seal leak.
Old Sep 26, 2019 | 12:09 PM
R 320 CDI
Took of the bellhousing rubber plug and cleaned up all oil....glued a piece of rectangular rubber underneath the bell housing hole with some strong silicone to determine if the oil spill came from inside the bell housing and left the hole open......but no, the spill does not come from inside the bellhousing!! The spill must come from the left side weep hole...but I'm not 100% sure...still investigating...
Old Oct 4, 2019 | 05:51 PM
houseofdiesel's Avatar
2008 R320 CDI, 2006 smart fortwo cabrio, 1983 240D, 1982 300SD, 1980 300SD
Did the oil cooler get replaced at the time of the seals? They are known to warp and leak, not just the orings fail.
Old Jul 5, 2021 | 05:19 AM
Mohammad C's Avatar
2013 mercedes s350 bluetec
New purple oil cooler seals leaked again
I have had this happen to me on my 2013 S350 bluetec. The first time I used all original Mercedes parts and then about 5000 miles later the oil leak developed again so now I’m thinking that the oil cooler itself has a warped so I am going to replace the seals again along with a new oil cooler. there’s simply too much heat where the oil cooler is located and therefore it it it just doesn’t last. Best to change out the oil cooler the first time.
Old Jul 5, 2021 | 11:21 AM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Can you please do us a favor and check the oil cooler with straight edge when you remove it?
imo it is more likely that proper torque was not applied to the oil cooler (due to thread/ block contamination) than cooler warpage being the culprit.
Old Jul 5, 2021 | 01:58 PM
Mohammad C's Avatar
the torque for the oil cooler bolts was done with a torque wrench and based on the book. The first time doing the seals I bought a new oil cooler from the local MB dealer along with the seals but did not use it. When placing the new oil cooler on a flat surface it would wobble as did my old one. So I figured it was normal—although strange. I have seen a lot of chatter about oil coolers failing as well due to warpage.
Old Jul 5, 2021 | 04:03 PM
Interesting. The only thing I can think that would affect the torque would be not cleaning the block holes. Given a rather low torque required on those bolts, I can't imagine taking these bolts off the oil cooler in some specific order would make any difference.
ive heared of a suggestion however to heat up the new seals slightly just before installation but oil cooler seals leaking shortly after exchange is rather rare event.
Old Jul 6, 2021 | 12:47 PM
B34chBum's Avatar
R320, Astro, JSW, ST4
If/when I do this job I will use a sealant along with the o-rings.
There's a non-hardening one I use to seal the camshaft seal uppers on the VW PD motor, for got the name/links to it.
It is brushed on from a small can - would be tempted to do all machined surface mating with the cooler.
Old Aug 18, 2021 | 08:27 AM
kkarb's Avatar
w164
I hadd the same problem. W166, ML350. Replaced oilcooler and seals 1 year ago. Still dripped a bit engine oil in rear right side of engine. To me it was the pedestall / beam gasked leaked. Dripped down at right side off the bellhousing. I removed the turbo once again, and replaced the pedestall / beam seals. One under beam an one between beam and turbo. I used a iphone endoscope to locate te leak, it was hard to detect. Se my pictures, its from the right side off the turbo pedestall.
