Limp mode! C220 CDi [CL203] - 2005
Old Jul 9, 2019 | 02:16 PM
HaloJones's Avatar
C220 CDI
SOLVED - Limp mode! C220 CDi [CL203] - 2005
Would love it if someone could offer some advice please as I'm at a loss as to where to go next!
About 3 weeks ago the wife's 05 reg C220 Cdi went into limp mode with no warning lights showing.
Put my diagnostic set on and it had no stored codes but did have a
Pending: P0299 code turbo underboost.
Checked all pipes, connections etc leading to turbo and no obvious sign of any issues.
Cleared code and it continued to run OK for about 3 weeks.
Two days ago it went into limp mode again. Still no dash warning light.
Diagnostics showed no stored codes again, although it did have pending codes.
This time they were:
P2084 Exhaust Gas Temperature EGT Sensor Circuit Range Bank 1 Sensor 2
P0299 Turbocharger Underboost
P2080 EGT Sensor Circ Performance Bank 1 Sensor 1
Unsure what to do about this I cleared all codes and set about doing a little research - not too successfully so far!
Today, took the car for a bit of a run and after about 20 miles the engine management light came on and it went into limp mode again.
This time diagnostic had one stored & one pending code:
Stored: P2A00 O2 Sensor Circuit Range/Performance Bank 1 Sensor 1
Pending: P0299 Turbocharger Underboost
Whilst I'm generally handy enough to do the work myself I am somewhat stuck as to where to start with fixing this! Really don't want to just swap parts at random as that's a very expensive way to fault find and simply not an option on such an old car.
Any advice would be truly appreciated
Old Jul 9, 2019 | 03:06 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Most likely the problem is with turbo actuator. Most common issue is worm gear is worn out and/or broken electrical connection.
If you know how to solder it is easy and cheap fix.
Old Jul 9, 2019 | 03:22 PM
artim808's Avatar
Never mind you have different engine, your problem will be something else but not actuator. Check the vacuum hose.
Old Jul 10, 2019 | 06:13 AM
HaloJones's Avatar
C220 CDI
Thanks for your suggestion artim808.
I didn't want to cloud the issue but after the first code came up (Pending: P0299 code turbo underboost. Checked all pipes, connections etc leading to turbo and no obvious sign of any issues.) I did replace the intake pipes(below), although ultimately this seemed to have no effect, therefore I didn't mention this - suppose I should have.
Replaced this
No other work has been done or replaced since.
Old Jul 10, 2019 | 12:43 PM
HaloJones's Avatar
C220 CDI
Is this a failed turbo - How can I check?
Old Jul 10, 2019 | 02:20 PM
artim808's Avatar
On OM642 engine is very common that electrical connection on turbo actuator is broken (see photo below). You can open the actuator and check the connection. It's easy and free fix if you know how to solder.
Old Jul 12, 2019 | 06:31 AM
HaloJones's Avatar
C220 CDI
@artim808 - Thanks for that. I don't have the OM642 engine but I will have a look and see if there is a similar set-up and issue. Will have to be over the weekend now.
Appreciated
Old Sep 13, 2019 | 06:55 AM
HaloJones's Avatar
C220 CDI
SOLVED!
Couldn't get anywhere myself so finally took it to a MB specialist.
Problem found to be that the N/S lower turbo boost pipe had a 2 inch split in it!
Pipe is tucked away somewhat but the mechanic said he could hear it sucking if someone else was throttling at the same time.
Hope that helps if you find you have a similar problem...
