Lady of the house pumped reg fuel into a diesel
Old Oct 5, 2019 | 08:49 PM
Peter5678's Avatar
ML350 diesel 2011 blutek
What a poo show. Towed 100 miles. Extracted bad fuel. Vehicle drives again. Now have a particulate filter alarm. Whats a guy to do to get this remedied.
Old Oct 6, 2019 | 11:02 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Get a scanner who can force regeneration.
If that doesn't help, you will need to remove DPF and send it to local shop who does the cleaning.
Old Oct 7, 2019 | 10:37 AM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
Liqui Moly DPF cleaner works well and not expensive. I would try that first.
Old Oct 7, 2019 | 12:40 PM
Peter5678's Avatar
How does a city boy like me remove that filter with your average garage tools
I found this place online that cleans said filter for 24 hrs. I’m willing to get it done right
Old Oct 7, 2019 | 12:53 PM
chsu74's Avatar
You inject the fluid through the PDF sensor plug hole. It will smoke like a crop duster. You don't have a location listed for folks to recommend local shops.
Old Oct 7, 2019 | 02:52 PM
kajtek1's Avatar
Before you consider Liqui Moly DPF cleaner check the below:
-price of LM cleaner injector
-application manual that calls for using cleaner with purge, so you have to buy 2 bottles and they are not exactly cheap
-location of your DPF. Most US models have DPF stuffed between engine and firewall.
Not exactly easy place to remove sensor and stick the probe.
Once again, start with forced regeneration.
Old Oct 9, 2019 | 10:17 AM
Peter5678's Avatar
I will attempt forced regen. Only discovered what that is yesterday. Thks
Old Oct 9, 2019 | 11:37 AM
chsu74's Avatar
It is not an easy place to get to for sure. I had 59 or 61 failed regen codes and cleaned it up with Liqui Moly. Sure beats the price of a new DPF.
