Delete Adblue, SCR, DPF question
thanks
Best IMHO way to do it is chisel out DPF honeycombs. That is what I did.
So the exhaust components is just the dpf?
i could chisel it out, just can’t immediately do it, can it run sometime with it on without any issues ?
When DPF removal on OM651 is child's play, doing so on OM642 is quite a task.
Driving it with honeycombs and DPF delete will eventually clog the DPF, so don't plan on doing it long.
and a 2011 E350
both bluetec
I also plan on replacing mine one day, but for now everything works..
the one tune will just disable the bluetec system (nox sensors, SCR, and uria spray) But also option for full delete (EGR, swirl flaps, DPF)
Im not sure why everyone hates on the OM642 engines due to emissions if it can all be simply,
removed..😀 In reality it will be same as the older generation cars..
Lot of things come to play in last years.
Now you can buy ScanGauge, who will monitor soot build-up and tell you regeneration status. That sure can avoid lot of troubles when you observe it and make extra loop to avoid shutting the engine down with pending regeneration.
MB also shoot itself in the foot with making complicated unit for DEF tank. Small heater burn out cost a fortune for whole unit replacement, than SCN coding comes to play.
On older diesel you can have new O2 sensor for about $100.
On DEF -equipement cars you have two Ox sensor, who replaced in pair can run you $1800 at stealer. Not much to love when it comes to it.
I monitored the results on scan gauge and it would randomly spike for high ppm.. The secondary sensor worked fine..
Like you said the sensor at the dealer quoted me $850 plus tax for just the sensor..
I found an aftermarket part for $75 with shipping and it has worked flawlessly for the past few months..I just had to splice in the new sensor to old module (8wires)
The sensor readings are now much more stable with very quick response ( for example once you let off throttle)
I completely agree, these cars need long highway drives and cannot be treated as a short distance city car..
If I start having issues with bluetec or DPF, its all coming out and a tune will be done at that point..
I do mostly long highway driving, so i foresee this system working a long time.. Currently 215,000km
