Eliminating cylinder wall glazing
Well, that's my motor for its first 100k miles. And the issue that he raised is cylinder wall glazing. So, how do you eliminate cylinder wall glazing??? Is this even possible? Is it helpful? I can probably do a leak down test but how will I know if it's the piston rings or the cylinder walls that are shot?
Now for engine testing, modern scanners will run "smoothness test" what is comparable to compression test, just way easier to do.
Now think about it - would successful shop owner seek donation on the internet for his retirement?
The part the OP displayed is only the metal elbow that connects the plastic CCV to the cylinder head. There are no CCV redeeming properties as its just a metal elbow without restriction. The areas circled in red are where the two parts connect. The OP's profile lists a W211 E320 Diesel, which makes this part era-accurate and not the one above.
