OM642 Oil change procedure
I am pretty sure I don't know all the versions, but I do know that OM642 has dozens of models. Not only filters and piping come different on different vehicles, but I know the engine is tuned from 168 HP in Sprinter vans to 250 HP in newer sedans. That's pretty wide spread in tuning.
So I just wonder if for Jeep application they modify the engine (again) and side effect is weak bearing? What's HP rating in Jeep?
It is a OM642.980 if that means anything?
It is 218bhp and 375ftlb torque.
I am not aware of any differences in the basic engine of the OM642 in different models. Odd indeed though that Jeep issued the TSB but Mercedes did not.
Many thanks.
There are several differences as far as I know. The 642.826 on my cars have water cooled turbo while older versions have oil cooled turbo. Also there's a plate installed under the oil filler port while older versions don't. The plate blocks the vision to the timing chain tensioner. 642.856 is tuned to 240hp in US and 255hp in Europe.
Yes indeed. My Jeep has an oil cooled turbo. Mine you can see the timing chain from the oil filler cap. Some jeep owners found out it can fire oil out with gay abandon if you fire it up without the cap on.
Jeep had used the OM642 since 2005-2011 in Europe.Jeep had used that engine for three years by then. Incidentally from 2000-2005 jeep used the OM612.
Would Mercedes really have made the OM642 with different bearings just for a Jeep? I am not saying you are wrong it just seems counter intuitive to me.
As an aside they shipped the Engines as a unit with the 722.6 transmission (Jeep called it a W5J400) to American assembly line. European ones were made in Austria by Magna Steyr
Thanks.
The Oil that Jeep specified in the owners manual and at the dealer was MB229.51 5W/30.
Maybe removing the belt takes tension off the bearing?
MB229.51 is a very easy spec oil to find in UK and the vast majority of Jeeps will be diesel.
I agree that it is all very strange. Mercedes owned Jeep back then so they will obviously have been aware of the bearing issues and it was happening enough to warrant a TSB. Go figure.
Thanks for taking time to help.
