OM642 Oil change procedure
Old Apr 23, 2020 | 09:12 PM
Jeep driver's Avatar
Jeep 3.0crd
Hi Gents.
My Jeep has the OM642 unit. Everything I read about this Engine in the Jeep says I MUST put half the Oil down the filter housing to 'coat the bearings'.
Is this just Jeep related Bull poop or has it a basis in reality? I have never read of anything official from either Mercedes or Jeep to support it.
Do you guys put half your oil down the filter housing?
Any opinions welcome.
Many thanks.
Old Apr 24, 2020 | 07:10 AM
virgisr's Avatar
Mercedes R320L CDI 4MATIC 2007
Originally Posted by Jeep driver
Hi Gents.
Many thanks.
My car has got om642. Never done anything like that and the instructions are not mentioning that as i remember.
Maybe this instruction is when you are adding oil for the first time to a brand new engine?
Old Apr 24, 2020 | 08:13 AM
Jeep 3.0crd
Hi
Thanks for helping.
No it applies to oil changes too. If you watch every Jeep oil change on 'you tube' or any oil change post on a Jeep forum they all say the same thing.' Put some oil down the filter housing, it's important'.
I wish I could get a definitive answer hence I came here to the 'home' of the manufacturer .
Great engine though. Pulls like a Train even with two tons of Grand Cherokee.
Many thanks.
Old Apr 24, 2020 | 09:00 AM
virgisr's Avatar
Hi
Thanks for helping.
Many thanks.
i again had a look at the oil change instruction if i have missed anything. It does not state anything like pouring some oil into filter housing. My engine code with extension OM462.950. Maybe that makes any difference? Do you know what numbers are after the 642 on your car?
I am attaching the instruction to which i am referring.
File Type: pdf
Old Apr 24, 2020 | 11:12 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Must be Jeep thing as I never heard about bearings coating on Mercedes.
Synthetic oil do have lot of Molybdenum, who makes semi-permanent coating, who give you good lubrication even with no oil.
Than fact is that oil filter housing is much more convenient for filling than the top hole.
Old Apr 24, 2020 | 11:23 AM
Etienne Lau's Avatar
Ml350 bluetec
Not required, it's bull poop being spread by Jeep group. Don't see how pouring oil into the filter housing would help the bearings on the crank shaft. The oil filter housing is on the front driver side of the engine, the crank shaft is in the middle and runs front to back. This is the same rumour going around that one should pre-fill oil filters when changing oil in other forums.....
Old Apr 24, 2020 | 02:01 PM
kajtek1's Avatar
Originally Posted by Etienne Lau
.. This is the same rumour going around that one should pre-fill oil filters when changing oil in other forums.....
Well... my Ford Truck has spin-on filter hanging under the engine.
With its 2 quarts capacity , the oil pump will spend several seconds to fill the filter before oil will go to engine.
So I am filling up those filters before installation.
MB has top-mounted filters, so you don't have this choice, but than filters have like a cup capacity, so fill up is much shorter.
Old Apr 24, 2020 | 05:21 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I've always pre-filled my oil filters when they were mounted where God intended; underneath facing up. Before I started to do so, sometimes I would hear the engine clatter a bit on start-up 'till the oil filled the filter and reached the lifters etc. I've experienced it first hand. Eyes on the oil pressure gauge, the clatter would disappear the second the gauge jumped back up. Rumour for some, fact for others...
I dunno about pouring oil down the oil filter housing, though I sorta see the logic of it. If that passage has gone dry due to the oil-filter and oil change, then the oil has to fill the new filter and also travel down the oil passage to get to the oil circuits. Having said that, I've never heard the MB clatter following an oil change. I still try to pre-soak the new filter in the hope that it will get the oil going thru the circuit quicker, but I don't know what difference that makes, if any.
Old Apr 26, 2020 | 08:00 AM
Jeep 3.0crd
Hi Virgisr.
Thanks for the pdf. It would seem that Mercedes never thought it important enough to mention.
I do not know what variation of engine I have and not sure how to find out. I looked at the factory build sheet and it just says OM642.
It has a 9.5 litre oil capacity unlike the one on your PDF that states 8.5 litres.
Interesting too that the Jeep 722.6 uses ATF+4 and not the Merc' spec.
Thanks for everyone helping.
I cut and paste this from a Jeep forum. The guy 'merlin' is a Jeep mastertech so does at least give some credence to his words. Older post but still relevant.
Opinions please?
https://www.jeepforum.com/forum/f67/...-grand-493293/
Thanks.
Old Apr 26, 2020 | 10:35 AM
kajtek1's Avatar
What post on Jeep forum says about lubricating bearings?
There is long way from Master Technician, aka a guy who can operate wrenches to top-end engineer designing MB engines.
Old Apr 26, 2020 | 12:27 PM
Yup, "top end". I'm guessing the same top end engineers who designed the EGR system, as well as the DEF set up. You know, the ones that takes a dump before the vehicle has 25k miles on the odo.
Maybe the same genius who designed our blind spot system, which took a dump on our truck at 40k miles? Not to mention the bean counters, who ultimately decide what the "top end" engineers get to implement in the actual build of the vehicle.
Yeah Krzy, top end!!!
Old Apr 26, 2020 | 03:50 PM
kajtek1's Avatar
There is also big difference between engine mechanical design and adding emission gadgets to it.
Think about it?
Soon any tire changer with 2 hr of job training will spam the net about Bluetecs. They are professionals working in the field afterall.
Old Apr 27, 2020 | 08:09 AM
Jeep 3.0crd
Hi
Fair enough, in this post he says 'to prevent crankshaft damage'.
Master tech is the leading mechanic in a dealership so in my opinion is worth listening to. Also he does say he got this procedure direct from Jeep so does that carry any weight? I concede it is curious why Jeep/Chrysler advised this and not Mercedes.
Many thanks everyone.
Old Apr 27, 2020 | 01:59 PM
kajtek1's Avatar
Master tech is the leading mechanic in a dealership so in my opinion is worth listening to. .
Not when he is trolling about stuff he has no education and no experience for. This is not just a comment on this sample, but we had several links to Stephens articles who had the same problem.
Would you find the mentioned Jeep note on the issue, that might be interesting. Otherwise I don't pay much attention to trolls.
Old Apr 29, 2020 | 11:06 AM
Jeep 3.0crd
Hi
A little harsh to accuse an apprentice trained, jeep main dealer master tech as having 'no education and experience'. In UK 90% of the Jeeps and Chryslers he will have seen will have been OM642. As for being a troll, well your idea of one is different to mine.
No, unfortunately he did not post any documentary evidence. Hence I came here to ask on a Mercedes forum.
Thanks.
Old Apr 29, 2020 | 06:54 PM
kajtek1's Avatar
Hi
That is how I can tell educated and knowledgeable person from troll.
I think you misunderstood my previous comment. Master technician is master in technical repairs.
What does he know about designing oil systems on top of the line engines?
This is not his job description - plain and simple.
Old Apr 30, 2020 | 11:38 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
This is a common practice developed by auto mechanics, but not called for by any manufacturer service manual. The main purpose is to shorten the time of the oil pressure buildup, during which the engine is basically running without oil. Most of our auto engines have wet-sump oil system that oil runs from oil pan to pickup tube--oil pump--oil filter then to every part that needs lubrication. Usually there's a one-way valve between the pump and the oil filter to ensure that the oil filter housing is filled after the engine shuts down. After an oil change, if the oil filter housing is not filled, then the oil pump will need a few seconds to fill the oil filter housing before the oil can be delivered to all the surfaces. This is why you can see the oil pressure warning light keeps on for a few seconds on the first start after the oil change. Pre-filling the oil filter housing can substantially shorten this time.
The fact is that, the difference is very small and the gain is probably neglegible. A few seconds without oil will not cause any damage to the engine at all. Most of time we change oil when the engine is warmed up so there should be some oil on most parts that will last at least a few seconds as well. But it doesn't hurt to do it as you are just changing a location to pour oil in and usually it's much easier to pour oil into the oil filter housing rather than the filler port.
Long story short, mechanics thinks it's a good practice INTUITIVELY and it's convenient for them to do so as well, but engineers who designed the engines don't think it make any difference.
Old May 1, 2020 | 01:45 PM
kajtek1's Avatar
If you are old enough, some of those "Masters" design electric oil pumps like 30 years ago.
The purpose was to start oil pressure when you open the door, or turn the ignition to on and have the engine cranking with full oil pressure.
Even that was dino oils era, the design never catch up as it did not make noticeable difference.
Than synthetic flood the market and they have high % of molybdenum in it. Molybdenum penetrate the bearings surface for semi-permanent slippery coating.
You should be able to find old movies showing engines who drained synthetic oils - making a mile run with no plug in oil pan.
Bottom line, even if you'd have a proof that it does make a change between engine dying at 300k miles v.s 320k miles. Would you care?
Old May 1, 2020 | 05:56 PM
lkchris's Avatar
'10 CL550, '12 GL550
The thing is, engines do NOT “run without oil” at first start after an oil change. Everything remains coated with oil, and this coating provides sufficient protection and lubrication during the (extremely short) pressure build up interval.
Even mechanics can conjure up theories ... they are never engineers that have designed, developed, and tested an engine.
Perhaps there are occasions where someone drains oil and then does not refill and start the engine for a week, but ... who cares?
Just learn to ignore mythology. This is 100% what the “Jeep” thing is. I for one do understand ...
Old May 1, 2020 | 08:14 PM
Parts coated with oil does not mean they are protected to the required degree. Once the parts start moving the coated oil will be depleted within a couple seconds. You need a constant oil flow to those required surfaces that's why we have oil pressure in the line. This is called pressure lubrication. The pressure buildup is quick because there's anti drain back valve that keeps the oil filter housing full. However when you change oil and put an empty filter in you will need a few seconds to fill the oil filter housing before the pressure can be built up in the line.
Old May 2, 2020 | 01:19 AM
kajtek1's Avatar
Oil will not deplete from bushings in couple of seconds.
Growing up in Poland, in my young years I was riding steam trains quite a lot. Lot of bushing in wheels drive did not have constant lubrication. At each stop the machinist would take an oilier and put few drops of oil on each bushing.
That was good till the next stop.
I bet lot of MB owners had no idea what was the purpose of the tool
Old May 2, 2020 | 12:07 PM
I know this! I remember there used to be one in my family when I was a kid. My father used it to lubricate the sewing machine (a big floor model powered by a large foot pedal) and the bicycles. Now I have a simplified plastic bottle version of this but I seldom use it due to the availability of aerosol cans.
I believe the oil light on the dashboard was inspired by this lol!
Old May 5, 2020 | 11:09 AM
Jeep 3.0crd
Hi Lads
Thank you all for replying.
I did find a Jeep technical service bulletin about the OM642 and crankshaft bearing issues. If you read it says the problem can occur after an oil change.
Was this TSB sent out to Mercedes garages?
http://www.wkjeeps.com/TSB/tsb_wk_0900108.pdf
Thanks.
Old May 26, 2020 | 09:00 PM
Jeep 3.0crd
Hi
The Jeep uses the OM642.980.
Thank you.
Old May 28, 2020 | 02:02 PM
kajtek1's Avatar
Hi Lads
Thanks.
Never heard about such TSB for Mercedes.
I am pretty sure I don't know all the versions, but I do know that OM642 has dozens of models. Not only filters and piping come different on different vehicles, but I know the engine is tuned from 168 HP in Sprinter vans to 250 HP in newer sedans. That's pretty wide spread in tuning.
So I just wonder if for Jeep application they modify the engine (again) and side effect is weak bearing? What's HP rating in Jeep?
