Whining/scratchy noice from around EGR valve
Old May 2, 2020 | 06:12 PM
W211BT's Avatar
2007 Mercedes E320 bluetec
I have 07 e320 and I just did a oil cooler change and I have a loud whining noice when I accelerate. The noice looks like it’s coming from around my EGR valve area not sure what it can be. The dealership said it might be a bad o-ring but not sure. When I let off the gas you can’t really hear it anymore..
Old May 3, 2020 | 10:20 AM
Oliver1232's Avatar
2006 E320 CDI
It is your vehicle whining telling you to delete it off of the vehicle so it can breath lol
Old May 3, 2020 | 10:27 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I had the same annoying noise, but it disappeared as soon as my mother in-law got out of the vehicle......
Sorry bud. Not trying to make light of your dilemma, but this was too easy to pass on.
Old May 4, 2020 | 01:19 PM
B34chBum's Avatar
R320, Astro, JSW, ST4
Jokes aside, are you describing a boost leak?
Usually they sound like a whistle, like whistling through your teeth, and yes it's when you "gas on it".
The EGR valve is near the firewall, but you may be talking about the inlet/blend assembly in front of the motor?
Regardless, I wouldn't try to locate leak by ear but rather look for oil leak(s) and replace leaking orings and seals, checking connections on the pressurized path from turbo around to the intake manifolds.
Something's either loose or wasn't replaced.
