Bad def heater level sensor
While i was working on the car ,I was able to get the downstream Nox sensor out. It was heavily coated with a white residue , similar to what I saw when I took the DEF injection nozzle out. Is this normal? What is the best way to clean the sensor?
Thanks, E350cruiser
From what I know - you will need dealer to reset the counter, leaving you not too many choices.
To clean the NOx sensor I have herd of people soaking them in Diesel injector Cleaner overnight then drying them with carb cleaner, and that may work. I just replaced both of mine with the ones XeModeX makes. They are not cheap Chinese crap either they have them made in Canada custom. They are not BOSCH either which those are the OEM and they are also crap.
I also got the scoop on the emission's recall form my Mech. So here it is. They will proceed by model year older ones first as they have more problems and sprinter service vehicles as well. The deal will be a complete replacement of your exhaust and adblue system with an updated system that actually works from the Turbo back plus $3800 to cover any repairs that the owner has had to do. If you are not the original owner then you get $2400 and the previous owners will split the other $1400. I will loose of course because I have already spend well over $4900 in the last 3 months on my adblue and emissions system which is as follows:
2 NOx sensors (XeModeX) = $650 no labor as I did it myself it would have been $1500 parts and labor because of the stupid one forward that is routed under the heat shield. BTW I did reprogram the sensors so that is not the reason for the codes.
1 XeModeX DEF heater mod = $600 no labor as I did that one myself.
1 adblue Injector = $750 done by the Mech.
1 CAT = $2300
1 New adblue Pump = $600 (this was a steep discount because my Mech felt really bad about me funding his next trip to Hawaii with my emissions woes.)
So the emissions recall and compensation will not even cover it and this is all just to keep the thing on the road. I thought about a delete kit but I live in CA and that just won't work next time I have to get the damn think SMOG'ed.
All this though and I still absolutely think my GL350 is the best thing on the road. but the next major thing that happens I will drive it off a cliff!
Nox sensor probes sell new on ebay for $80 and replacing probe only you avoid SCN coding on newer cars.
Aftermarket new DPF sell for $600-1000.
1 CAT = $2300
My E250 is scheduled to go into the dealer for the modification on Monday. In speaking with the service advisor, nothing in the AdBlue tank is part of the campaign. I'm also having an AdBlue level sensor fault, and if it isn't handled by the dealer when my car goes in Monday, I'm just going to change the heater assembly myself.
When campaign is not replacing DEF tank, it is subject to extended warranty.
The case is tricky as to get the warranty you have to do the campaign, but there is no note in the campaign that they can't do it with malfunctioning DEF.
The campaign started just a week ago, so we all wait how MB USA is going to play it.
Here is the campaign site.
https://www.epa.gov/enforcement/daim...vil-settlement
I did not have the wrench I needed to get the upstream nox sensor out yet , so Im not sure of its condition. If i can get it out I will try to clean it before replacing. If I have to replace any of the sensors, perhaps the xemodex sensor is the way to go.
Thanks for your input, appreciate it.
I also put the xemodex level sensor and heater in this past week. Does the DEF tank have to be full when installing a new level sensor/heater? At home from work sick, I havent had a chance to get another container of DEF yet. If not, will the 10 start remaining warning go out now that I have a new unit in the DEF tank? I had a error code for reductive level sensor, I think it was P20be. I also had P2BAD What does that mean? Nox sensor bad?
My Car is on the list for recall, but will not get the repair work untill the end of the year. If my Nox sensors are needing replacement They require "initializing" .Who does that? I was looking around for replacement sensors, There are sensors available on Ebay and Amazon. Are the upstream and downstream the same part? If Not ,What are the factory part numbers for my car? 2011 E350 w212
Thanks, E350cruiser
Here is link to $70 NOx sensor probe. You splice the wires and leaving old module doesn't require resetting anything.
On my 250 BT both NOx sensors are the same, but that's where checking EPC comes handy.
https://www.ebay.com/itm/A0009053403...2/123420825896
not to sound stupid, but what is SCN coding and SD? I am not an auto mechanic. Does that mean a trip to the dealer?
Thanks, E350cruiser
With MBUSA it start at about MY 2014, but farming machines had it even longer.
Since most of vehicle attachment those days have separate computerized module - manufacturers include software that require connection with main factory to program the module to the vehicle. My Sprinter radio went into security lockdown and it took dealer's PIN with about 1/2 hr of internet time to unlock it.
It is called SCN coding and require internet connection with Stuttgart to perform, but imagine how much your milk or potatoes price will go up, when farmer's $2 mil machine breaks on the field and they will have to wait a week for technician to make it there.
You can object the procedure at https://www.repair.org/stand-up
