Hello
i have ml 350 bluetec 2011 and i have the error code
11C300 The upper limit value of component B4/6 rail pressure sensor has been exceeded. I have already replaced the pressure sensor injectors fuel pump but nothing.
fuel pump crack at 1500 rmp
help please
help please
Quote:
my problem is that my car has check engine light on and my high fuel pump start rattling when i try to accelerate.Originally Posted by Plutoe
your post does not make any sense----what is your issue
also when i pull out the cable from the rail sensor everything is ok the rattling noise stop .
this car is making me crazy
I would first test the high pressure pump output with mb star. Its a short test, rpms are increased till certain pressure and the car runs for about a min and shows how steady the pressure output is.
kajtek1
close
- Join DateJan 2009
- LocationV E G A S
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive1922 Ford Model T / no OBD
Liked:1,798 Times in 1,426 Posts
Regulating the rail pressure is the job of pressure regulator.
Don't see it addressed?
Got to love members who drop couple grands in parts, before asking for advice.
i have changed rail sensor couple of times still hearing that noise after 40 sec engine startOriginally Posted by kajtek1
Regulating the rail pressure is the job of pressure regulator.Don't see it addressed?
kajtek1
close
- Join DateJan 2009
- LocationV E G A S
I have y74 pressure sensor below normal Can this couse rattling to fuel pump ?
hello
John CC
close
- Join DateJun 2021
- LocationNew Hampsha
- Vehicle(s) I drive'17 GLS450, '14 GLK250, Grandpa's Roadster
Liked:521 Times in 420 Posts
Why do people tend to blame the sensor? The sensor is telling you that there is a problem with fuel pressure. We say "don't shoot the messenger!"
ExploreQuote:
please what do you suggest?Originally Posted by John CC
kajtek1
close
- Join DateJan 2009
- LocationV E G A S
Judging from the screen language (Italian ?) - English is not OP 1st language and I see now that some misunderstanding might be due to that.
1st the test calls for full engine operating temperature, what was not met during the test.
Now I see the fuel pressure is too low, when "exceeded" in original post suggest it as too high.
Than as Honda suggest - focus on high pressure test, not on general test.
yes the temperature is not correct because test was in the morning 3 min after car started.Originally Posted by kajtek1
Judging from the screen language (Italian ?) - English is not OP 1st language and I see now that some misunderstanding might be due to that.1st the test calls for full engine operating temperature, what was not met during the test.
i will do the HP pump test and share here the results
thanks a lot
