99 E300 D No Start & How to bypass
Hacking digital car can end pretty badly if you don't know precisely what you are doing.
What's the car voltage? No lights when you turn the key? Do you hear steering wheel blockade moving when you insert the key?
benzworld has good archives on W210 generated by very knowledgeable people in the past. Only new "crew" seems to make 100 replies topics about nothing.
Why don't you just try running a jumper wire from the battery plus to the starter solenoid?
You seem to post under 2 different handles and are not answering the questions in straight way. That puts the topic in "garbage in, garbage out" category.
Again, you are not posting technical results, when not knowing your knowledge the "its good" answer is not sufficient.
Post the numbers and we can go from there.
