Does Liquimoly 2037 Pro-Line Engine Flush fix the oil consumption ?
Modern oils are known as having big pack of detergents and those who drove the cars when synthetics come on the market might remember lot of warnings that new generation oils work as flush and they suppose to observe the oil after such change and do the following oil change after low mileage.
Meaning if you run on oil with high flush value, what do you expect from additional flush?
On other hand, if you are thinking about engine replacement, what do you have to loose?
I drive MB diesels for decades and even some of them exceeded 200k miles, the oil consumption was never a problem on them. Having contact with some buyers of my cars, couple of them exceeded 300k miles and still no problems.
I stick with FSS recommendations for oil change.
But I am also believer in Italian tune ups and from time to time I floor it on freeway ramp.
I pulled the record
oil changes were done by previous owner
8,962 miles
25,026 miles
38,045 miles
i bought it at 41,000 miles
I did oil as follows Mobil1 5w-40 was used through out
48,252 miles.
59,299 miles
72,570 miles
83,883 miles
93,706 miles
108,303 miles
118,653 miles
131,238 miles
141,870 miles
150,528 miles
160,018 miles
160,808 miles AEM modification done per MB Emissions class action settlement - new DPF installed
First time I notice excess oil consumption
168,432 miles - oil change - start oil consumption test
170,467 miles - oil consumption test ( fresh oil fill)
car failed oil consumption test ( 800 ml per 1,000 km, turbo was changed out )
186,642 miles - shop used 0w-40 for the first time in it
188,346 miles - start oil consumption test (fresh oil fill)
189,886 miles - oil consumption test (fresh oil fill) test result 700 ml per 1,000 km, nothing done as it was 100 ml from the failure
car has 197,000 miles on it today. I am picking it up with a new DPF filter and repaired two leaking fuel injectors
i am taking it for oil change where I am switching from Shop using Mobil1 to Liqui Moly Top Tec 4200 5w-30
I will start therapy of Liqui Moly engine flush every 5,000 miles I’ll add two cans and after I’ll add Ceratec.
UPDATE: picked up the car today. NEW catalytic converter and NEW DPF....crazy stuff...covered by warranty due to MB Classaction Settlement. Doing 620 mile oil consumption test. Results next week...
Not trying to start another oil dispute, but I test my oils and Mobil 1 lost my faith over a decade ago due to generating high iron. Additionally the manufacturer representative dodged the question on internet chat room, what is not building confidence.
Than 0W-40 was definitely not 229.52 classification oil, when other topic on this forum proves that Bluetecs can be very sensitive to lower classification oils.
Since I start driving DEF-generation of Bluetecs 5 years ago, I am using
Motul 109471 8100 X-Clean EFE 5W30
oils and lab test proves their excelent performance
