OM642 NO START please help!!!
Old Feb 23, 2022 | 07:51 AM
08jeep0m642's Avatar
2008 jeep cherokee crd 3.0
Ok I know there's probably a million posy about this issue but I'm honestly tired of trying to get this engine running...
To start i own a jeep cherokee with the 3.0 diesel in it. The jeep developed a pretty decent oil leak. Found out the oil was coming from the oil cooler gaskets. The jeep also developed a hard start issue as the oil leak got worse. It got cold here and the hard starts got worse and ended up burning the starter. I changed the starter and did a leak test on the injectors. Ended up changing the injector and it ran fine for awhile. Hard start came back so I assumed it might have something to do with the oil leak... did my reasrch ordered the parts and dove into tearing it apart... (PAIN IM MY A**).. got the oil cooler gaskets changed and all put back together... turned the key and she fired after about the 2-3 time... ran 45 min no issue. Shut the engine off and it wouldn't start back up... let it sit put by battery charger on it and went home.. came back the next day tried to turn it over after about 3-4 cycles of the key it fired took it for a short drive.. it started bellowing smoke and cel came on limpped it back to my shop and scanned it and it was a turbo underboost code. Clear it cause right as I was pulling into the shop it started running good again. But now it was zero start just cranks.
I have checked all lines for leaks, made sure no air in the system.. i got it to start last night and it will idle but once you start to rev it the engine shutter like it's starving for fuel or something idk....
we have reprogrammed the injectors and changed fuel filter and crank sensor... i dont wanna just keep throwing parts at it so if someone could help point me in the right direction of what to test or anything i would greatly appreciate it!!
Old Feb 23, 2022 | 10:00 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
what's the rail pressure?
Knowing mileage would be helpful as well.
Old Feb 23, 2022 | 10:52 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
How much oil is being dumped into the intake?
Old Feb 23, 2022 | 11:10 AM
lancemurdock's Avatar
2010 GL350 Bluetec
Just remember on a diesel there is no spark to ignite the engine and start it, its all compression based...so sadly many no starts on these engines sometimes point back to low compression...you can assume where it goes from there.
Old Feb 23, 2022 | 02:23 PM
Originally Posted by Plutoe
and you wanna know why the car wont start-----all the answers are in your post, look in a mirror
Your comment makes no sense but thats
Old Feb 23, 2022 | 02:24 PM
Rail pressure goes up to 2000ish psi when trying to start and it has 160k miles
Old Feb 23, 2022 | 02:25 PM
I know that I own quite a few diesels and it has compression thats not the issue
Old Feb 23, 2022 | 02:26 PM
who said anything about oil being dumped in The intake?
Old Feb 23, 2022 | 04:30 PM
2010 GL350 Bluetec
Cool so you've done a compression test on the engine then? what were the readings?
Old Feb 23, 2022 | 06:38 PM
2013 ML350 Bluetec
I did, because you posted up that you were blowing smoke and having low turbo pressure issues.
Contentious much?
Old Feb 23, 2022 | 09:08 PM
2013 ML350 Bluetec
2000 psi is low for a common rail diesel.
How's your fuel pressure regulator seal?
Old Feb 24, 2022 | 10:02 AM
kajtek1's Avatar
You need close to 5000 psi on the rail for the engine to run.
Time to do some testing
-injector leak test
-fuel pressure regulator
-HP fuel pump.
We still don't know the mileage, but HP fuel pumps don't last forever, nor do injectors.
Old Feb 24, 2022 | 12:47 PM
-injector leak test
-HP fuel pump.
When turning over it has around 2900 psi when it starts it 4000+ the jeep has 160k miles.
Old Feb 24, 2022 | 03:33 PM
2013 ML350 Bluetec
When it is running it should be well over 20Kpsi... are you seeing that?
Old Feb 24, 2022 | 08:04 PM
kajtek1's Avatar
20Kpsi would be high rpm under load.
My engines fire on 1st turn, so I can't clearly see what is cranking rail pressure, but at Idle I am having min 4800 psi. Will double check tomorrow, but taking differences in engines tune, you might want to get data from fellow Jeep owner with the same setup.
Old Feb 25, 2022 | 04:11 PM
B34chBum's Avatar
R320, Astro, JSW, ST4
"all put back together... turned the key and she fired after about the 2-3 time... ran 45 min no issue."
Okay, you dove in deep with it, and lived to tell the tale - at least part of it. Let's see:
- Oil cooler seal job, that's the big one
- Injector(s?) - how many, I can't tell. reprogramming means I think putting new numbers in, so I trust you have a scanner/computer which can talk to your Jeep.
And, you were successful.
Then, not.
Ignoring the under boost code for a moment.
This sounds like injector spill line o rings not sealing and letting air in (at rest). Or somewhere else in fuel supply letting air in.
Make sure battery has good charge, and do key on and listen for lift pump on. Leave key on for 30 seconds before starting.
And check all the lines again.
