BG 245 fuel system cleaner testimonial
Old Jun 8, 2022 | 12:23 AM
excal's Avatar
W166
Just want to sing the praises of this product. W166 OM642 engine - I was dealing with a slight hesitation at idle that gradually become worse over time and finally ending with a 13B800 CEL "Maximum actuation duration for zero quantity calibration for injector 4 exceeded". Oddly enough it was only noticeable in neutral, not in D while stopped, but eventually became felt all the time. The car felt sick.
I poured a single can of BG245 and topped off with diesel. Gradually the symptoms improved and by 1/2 tank I was back to the slight hesitation. I cleared the code and it has not come back. Now having nearly finished the tank the idle is smooth as new. I never really believed in fuel additives before but this one really does work.
Old Jun 8, 2022 | 11:06 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
What's the mileage?
Sounds like now you might be ready for intake cleaner?
Old Jun 9, 2022 | 08:21 PM
Babukb2's Avatar
ML350
adding a thumbs up to BG 245. Read some great info and reviews regarding it, but not much out there as it doesnt seem to be very popular. Had a indy mechanic also highly recommend it saying they use it and it helps. For me i want to say it smoothed out my idle. I now use it about once a year.
Havent used the liqui moly intake cleaner though, @kajtek1 did you have good results from it?
Old Jun 10, 2022 | 12:18 AM
kajtek1's Avatar
Having several Bluetecs in my stable, I bought 3 cans of the cleaner over a year ago, but did not have enough motivation to use it. yet.
My engines run perfect and I don't drive much anymore.
But intake replacement on OM642 engines is consider a higher mileage maintenance by dealers and it is easy to spend well above 2 grands for the service, so the can looks really tempting.
You can find some videos on youtube about the procedure, what is not simple and good reviews.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
