320 CDI OIl?
Now I am getting somewhere.
I am in NC so our normal mix is 5%, with a cap at 10%. I also hunt for real D2 when I can find it.
I have never had an issue with oil level rising (a sure sign of dilution)
Does 229.52 deal with dilution that much better than 229.52?
I would assume (please correct me if I am wrong) a big problem with dilution is the associated lose of viscosity and lubricity.
Does a 0w40 buy you a little protection compared to 0w30?
If so, does it make up for some of the difference between .51 and .52?
is the CK4 rating a canard in this discussion, or does it have some merit?
Same question for the 228.51 discussion?
0W-40 is thicker than 0W-30 at operating temperatures and thus flows less readily. As the oil is the primary means of cooling the engine internals, less oil flow creates hot sports within the engine and in turn leads to premature equipment failures (various bearings for example). There have been ZERO reports of 0W-30 oil being inadequate - as in not thick enough - for all operating conditions of the OM642 in all climates. Putting in thicker oil than required in this case only shortens the life of the engine and increases fuel consumption.
CK-4 is a minimum standard for commercial vehicles and off-road equipment, just like the API Sx standards for gasoline engines. Trucks and bulldozers are not subject to the same emission requirements as passenger vehicles and their emission control systems are designed differently so it is not applicable here in any way, just like a gasoline oil with an API SN rating does not necessarily meet Porsche A40 or MB 229.5 lubrication standards for example.
MB 228.51 is a very oil spec and no longer applicable. In your particular case (i.e. 15-20-year-old engine in which you could use MB 228.51 oils when it was introduced), the oil spec change is necessitated not by the engine itself but rather by the chemical makeup of the diesel fuel that you're now putting in, which is not the same as it was 15-20 years ago. If you had pure dinosaur juice diesel (B0) you could continue to use an MB 228.51 oil with no ill effects, but unfortunately B0 is not what comes out of the pumps these days.
Read the chart carefully.
You might notice that recommendations changed via MY.
OM642 engine was (is ?) in production for over 20 years and changed quite a bit.
From no emission system, to fully blown DPF and SCR system
The oil recommendations changed as well and latest models do require 229.52 oils only.
The same engine in a Sprinter with very similar DPF/Exhaust system year by year, shows 228.51 229.31/51/52
So, setting aside fuel milage, and focusing on longevity of the engine and DPF, . . . .
. . . Anyone have a recommendation (with rationale) which oil is best.
EDIT: Just read your last post;
The M642 was sold for many years running 0W40, so why would you think that doing so might cause hot spots? (Note: Current M1 X3 ESP 0W40 is showing 229.51/52)
While heavy equipment and large trucks engines are different, a lot of light and medium trucks use automotive like engines and emissions system, (Including Sprinters with M642 engines)
Yet, in these applications MB recommendations include 228.51 (Which carries a specific "diesel" certification missing from most all 229.51/52 oils.)
My edit to the last post.
I know it can be a bit overwhelming to start, but learn how to scroll to what you need and check it before each oil purchase to check for updates.
Approved oils come and go, so what you used for last change might no longer be considered good.
That happen to popular Mobi1, who seems to reformulate the oils to come back on the wagon.
As what oil is the best, I posted lab results for Motul, that I considered the best. There is no independent research who will answer that question for you.
You can find comparing mechanical characteristics on "Project Farm" youtube channel, but that is all I could find.
Valvoline European Vehicle Full Synthetic XL-III SAE 5W-30, MB 229.52 rated, price varies from $78.72 to $102.57 for a case of 3 - 5 quart bottles from Amazon.
Both carry an ACEA C3 rating. According to ACEA, C-grade oils are stable, low-friction, and low-viscosity oils. They are used in vehicles equipped with diesel particulate filters (DPFs) and three-way catalytic converters (TWCs). C-grade oils are also used in high-performance diesel and petrol engines that require the use of oils with low levels of SAPS content.(Valvoline)
Rationale: best specs for the buck. SAE -30 oils are recommended in (my) operator's handbook without an upper ambient temperature limit. As long as you can maintain pressure, you will be fine.
I guess a more direct question is what usually fail in these engines, and what oil addresses that issue without being too bad on the DPF?
I have assumed it was Cams and Cam Chain stretch/wear, followed by less frequent bore scoring (and seeming rare bearings).
Doing all I can to keep good fuel in it. (Buy only at high volume stations, avoiding 20% Bio when I can and getting D2 when I can.
Adding a dose of PowerServ every few tanks.
Try to keep short runes to a minimum, etc.
Double check this; Pennzoil Platinum Euro L Full Synthetic 5W-30, It shows 229.5 not 229.51
https://www.walmart.com/ip/Pennzoil-...sRedirect=true
Didn't see it on the Pennzoil site.
Seems they have a different site for their Euro oils.
There is also an LX that is 0w30 and 229.31/51/52.
My oil was from Autozone.
They have a deal to get 5 qts plus a filter for 43.
I needed the filters anyhow.
You usually get an additional $5 to $10 discount for a first order.
I had to try a few times to let me pick the right oil, as it keeps sending me back to other oils.
There is a button to swap products.
It even picked the wrong filter, and I had to swap it out also.
Just to be clear I am not saying 15w40 is the best oil for mercedes OM651 or 642, can only recommend what MB does technically as I have not tried the others in my car but do run them in my cummins 3500 except in that thing I do 15w40 conventional with 12-15k mile change intervals. Have about 168k miles and just shy of 4k hours on it right now.
However, the point is the most common 299.51 oil in the US (the Original Mobil1 ESP) was 0w40, and that is what MB recommended.
About the same time 229.52 came out Mobil1ESP became 0w30, and the 0w40 became almost impossible to find. (I don't recall if that version of ESP ever showed a 229.52 marking.
If you look on the MB approval page, you will see almost no 229.52 0W40 oils, but many 0w30 and 5w30 oils.
The 229.51 page shows far more 0W40 and 5W40 oils.
So that is not the only thing, bit des appear to be significant.
Diesel oil for diesel engines. If it doesn't say CK-4 on the bottle it's not going in my engine. MB used to be aware of this obvious fact but then they got carried away with trying to chase down 1% fuel economy improvement and protecting the all mighty DPF at all cost, even if it means early engine failure.
I've got a bridge to sell you.
And decided not to use oil dipsticks. And decided that transmission fluid was lifetime fill.
Almost every engine oil manufacturers has one or more CK-4 oils available on the market. The standard is updated every few years so CK-4 supercedes CJ-4 which supercedes CI-4... you get the idea. There is a separate gasoline engine oil standard put out by the API currently called SN which supercedes SM. Some oils carry both CK-4/SN labels. CK-4 diesel oils are designed to work with DPF.
"API SN SM, MB 229.31, MB 229.51, MB 229.52" but no CK-4 because it doesn't meet the minimum requirements for a diesel engine oil. It's a gasoline engine oil yet people still pour it into their diesel. Mobil makes some excellent CK-4 diesel oils but this is not one of them.
