99 e300 smokes under heavy acceleration
99 e300 215k and anytime I hit the pedal quickly I get a puff of black, heavy acceleration is a cloud.
Here’s the weird part, no boost leaks, no CEL, egr has been deleted and capped for a while, no power loss, got 31mpg average on a 6000 mile round trip going 75-80 (so pretty solid mpgs) . It doesn’t burn any oil between changes. Starts on one glow cycle with no smoke or hesitation, if it’s above 50f it will fire immediately without cycling. The cat was removed by the previous owner, Boost comes on quick and if I go with mild pedal it won’t smoke. Same with once I’m at speed.
I’m kinda out of ideas except injectors. But has anyone ever seen poor spray pattern with no issues starting and decent mpg?
thanks if anyone has an idea where to look next!
Here’s a picture just because.
At 215k miles you could test the injectors, but start with basic stuff.
New filters, new fuel clear lines and make sure you don't have air in the fuel.
Check intercooler system for leak, what would show as oil stains.
This is 1st generation of digitally -controlled diesel, who still has mechanical injectors.
Meaning some poof at acceleration is normal.
the air filter and fuel filters were all changed 7000ish miles ago. it has also never made any smoke till recently so can’t just cough it up to being a diesel
I would send injectors for rebuild or at least testing.
If you have European connections, the rebuilds can be very cheap.
Deplore was discouraged from this forum, but he is indy, still driving the E300DT (who I sold to him).
I would contact him on benzworld for "hands on experience" advise.
Has anyone with a 606 experienced poor injector spray patterns without the usual other symptoms (hard start and poor fuel economy)
Black smoke means it's overfueled. So, either the ECU is sending more fuel than it should, or you're getting less air than you should. Check the air filter, and the entire intake tract for obstructions. Make sure the turbo(s) are healthy. Can you monitor boost? Are there under boost codes that could be set? Is there an air flow sensor that needs cleaning? There should be some device, or software, that limits the amount of fuel injected until manifold pressure has a chance to build.
The concept of "rich" and "lean" doesn't really mean much in the diesel world. Incomplete burning makes white smoke (unburnt fuel). Too "rich" makes black smoke from carbon in the fuel that doesn't get oxidized. This condition only occurs at or near full throttle. Under all other conditions there should be a surplus of air (lean).
and to the above I swapped air filters just to make sure and no obstructions. I have a good boost gauge and it shows a steady 18 at the center of the intake at wot which is the same as before the issue. I am not sure if it happened all of a sudden but I first noticed it on a grade at 8500’ elevation in Colorado. I looked in the mirror and realized I had blocked out the sun to a poor old Prius
As far as the sensors I usually use the MAF cleaner or whatever it is so no residue leftover. Not sure on your vehicle, my truck has about 3 or 4 sensors in the intake system that when I had them working, a cleaning seemed to help with smoothness and slight bump in mileage. They were usually clogged all to heck by the egr. Not saying thats the issue since egr capped may not have anything to do with it.
How hard are those injectors to clean? I know old school injectors lots of times ya can use small guitar wire to clean out the holes and or a sonic cleaner. Not nearly as finicky as modern injectors per say.
