OM 642 blow by
I have had a few of the om642 motors (normally higher km) and never had this issue
I have put a catchcan on it (years ago) and can feel pressure in the hoses (from pcv) but the oil filler cap has way more pressure.
I have to travel a few hundred km to get home so have routed the catch can vent out the right wheel arch so as to limit oil going into turbo (and intake) and have bought a heap of oil
No visible smoke out exhaust
I remember looking at a gl320 years ago at auction with similar high crankcase pressure but i just decided to pass on it so never knew diagnosis
any thoughts appreciated
I am going to try and vent from pcv straight to atmosphere and see if reduces back pressure. I remember the catch can I put on has a screen which may have been blocked
pretty sure the cause of the obvious leak was the dipstick moving out a little. Like if you pull it out a mm oil pours out.
You can run smoothest test, to pinpoint the cylinder and take snake camera to look inside.
The lack of blue smoke out the exhaust is a bit baffling to me.
thought if I had scored bores I would have oil smoke.
