2013 E350 OM642 Front Oil Leak
Completely cleaned/de-greased the engine, tech told to drive for a few days/about 1K and come back. Drove about 200 miles so far, at varying speeds, tried to examine the engine from above, did not find anything obvious. Filter housing is dry, anything I can see with a good flash light below it is clean as well, splash guards appear to be clean.
Have any of you experienced similar leaks (I have looked carefully here and on other sites, but have not found an answer). Any thoughts/advice on how to proceed? Love this car dearly! Thank you everyone.
My M272 engine had oil seeping out from the oil filter housing so I replaced both gaskets and it fixed the issue. The car had just hit 150,000 miles so I had to replace the coolant anyways so I crossed that off the list at the same time.
I was looking around for your oil filter housing and see its also made of metal like mine is. I found some gaskets that im thinking will fit your housing.
