OM642 Bypass AC Compressor
I believe that even in cold states, car without AC will loose lot of value.
As long as there is clearance for the belt (I don't have my car right now to look) so it doesn't contact other pulleys, sure, I can't think of any problems in doing so. Just measure the distance with something that doesn't stretch like poly strapping. You need to take into account the tensioner - but you could probably don that with the strapping by pulling it tight. OR... measure the current round trip with the belt off and compare that to the current belt length. Then adjust the new belt's length vs the roundtrip without the AC to match the difference.
What about ribs vs smooth vs pulleys? Probably won't matter for a short time, though.
How is the pulley attached? Can it be easily removed?
If it's not spinning there should be no further damage. If the problem is in the pulley/clutch, which is still spinning, then that can be (I assume) replaced separately.
And here is an excerpt after my success...
Long story short, the OM642 diesel will need a 78.5 belt to bypass the A/C compressor.
Unfortunately, the belt rubs on the seized A/C clutch and I didn’t check until I had everything back together. It will be fine for the short term (2 short trips this weekend) but I need to see if I can remove the clutch from the A/C compressor. If memory serves, I don’t think the clutch is replaceable on the GL350 compressor.
Thanks again for the support and hopefully this can help the next person stuck in a pinch.
And I never addressed the slight rubbing on the AC compressor and all is still well about 500 miles later. Also, when my compressor seized, the pulley did not break away. There is burnt rubber on the bottom of the pulley from the belt melting.
