Code P229F91 E250 Nox sensor
Old Mar 25, 2025 | 08:22 AM
benz54321's Avatar
2014 E250
So my 2014 E250 is running great and running smooth after replacing suspension components, tires and brakes. CEL came on ( code P229 Nox sensor ) so dealer replaced the sensor under the extended emissions warranty.
The car has 131000 miles. The car had the AEM update at 93000 miles so I believe the NOx sensors were replaced at that time. Going forward can I expect the NOx sensors to need replacing every 40K miles or so?
Anything I can do to extend the life of NOx sensors? Great car other than the ongoing battle with the emissions system. My scan gauge keeps tabs on the DPF, now if I can extend the life of NOx sensors !
Old Apr 10, 2025 | 05:00 PM
DaThresh's Avatar
2016 Mercedes E250 Bluetec Designo
What is the scan gauge that's keeping tabs on the DPF? I've been very curious about any preventative maintenance and monitoring I can do on my 2016 E250 (which has had the AEM completed).
Old Apr 10, 2025 | 06:28 PM
benz54321's Avatar
2014 E250
Go to Scangauge.com for more information. Scroll down to find Mercedes E250 2014 - 2016. I bought my scan gauge @ advance auto on line. I use the scan gauge to know when my DPF is regenerating. It is easy to setup. I have the Scan gauge ll. Mercedes could have installed a small gauge in the car to monitor the DPF, but for reasons I will never understand they didn’t.
I was at the Benz dealer a week or so back. I ask if the NOx sensors were failing @ about 35-40K miles. Service guy said yes especially with the new updated firmware they have to install. I have been emailing with Benzninja. He said he can recode so the NOx will last ten years minimum. The dealer charges about 1K per sensor. Fortunately I have not paid for one yet.
Old Apr 10, 2025 | 06:42 PM
DaThresh's Avatar
Other than monitoring, is there anything that we should be doing on these vehicles? I believe my car is about to fall out of the AEM covered warranty unfortunately. Just had both NOx sensors and tank heater replaced under the warranty a couple months ago - all clear/good right now.
Old Apr 10, 2025 | 07:31 PM
benz54321's Avatar
2014 E250
I am @ 132,000 miles - not sure what can be done to prevent future emission system problems. I am not worried about the DPF with the Scan gauge in place. I expect the sensors will be most of the problems. I plan to reach back out to benzninja. I do keep the engine air and fuel filter changed once a year or so.
Old Apr 11, 2025 | 12:28 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
My E250 is park right now, since I drive SUV in winter.
Nox sensors used to last long time, with occasional failures and I don't think they are subject to wear, but who knows.
I did check AEM scope and E250 BT did have new sensors installed with AEM. Manu fact, seems whole exhaust with DPF and SCR are new. When I was doing that, the SA told me it was $8000 job and MB mark DPF as rebuild unit, for discounted price.
I wonder what is current price for replacing Nox sensor. It was job going into 4-digits before AEM, as it require SCN coding, although you can buy probe only for less than $100 and easy swap it, leaving old module to avoid coding.
I still have 18 months of AEM warranty and I am happy about it.
E is my city car and DPF regenerates in city traffic just fine. Even if I abort DPF regeneration, it will resume next day once engine reaches 60C. Mind I live in hot climate. I used to drive with ScanGauge, but since now I have warranty, I moved gauge to SUV and don't worry about monitoring.
Newer MB diesels do have regeneration gauge on the dash, as well as DEF level gauge.
Old Apr 11, 2025 | 12:35 PM
benz54321's Avatar
2014 E250
Mercedes SA told me just a week or so ago that
that NOx sensors replacement was about 1K. Benzninja said he can recode & make NOx sensor last 10 years or more.
Old Apr 11, 2025 | 03:13 PM
kajtek1's Avatar
How much he charges for Brooklyn Bridge?
Mind Nox sensor is directly involved in engine efficiency, so any tampering with it has to end with lower performance.
