Deleting my DPF on my 08 CDI
You need to find someone in your area who can program the filter out. In terms of the hardware, you can simply help yourself and brake the ceramic filling of the DPF out with a crowbar. The result should be the pipe you need
In case you decide to stick with the DPF, then instead of cleaning / replacing the DPF, I would recommend to first find the reason why the DPF is plugged. In most cases it is a leaking turbo that fills up the DPF.
Once the root cause was found and eliminated, you can replace the DPF.
I've been running the car without exhaust for 5 days now and no real issues. It's not even that loud. I get a code indicating that the DeltaP is unrealistic (which I agree with) but its not causing any issues. I've been having a high back pressure code for a long time...and still do. I replaced it with a china sensor and its still showing 18psi with the sensor laying on top of the engine. I ordered a OEM one today. That's a good thought on breaking the media out of the DPF. I can't get to it on the inlet side because the pipe is long and curved. I CAN get to it from the outlet side. Will it break out from that end?
Regarding root cause - I suspect you are correct on the oil in the turbo. It's using a lot of oil. I replaced the Crankcase vent valve assembly 18 months ago and thought I had it solved but it seems to be back. I think I replaced it with a knockoff part also - can't remember. But... I gotta do something because its using a bunch of oil.
Regarding software updates on the ECM, I know what your saying... I had to do that on my truck but this vintage of Mercedes Bluetex doesn't seem to mind much. Of course there are things I may not know about that would create the need for this. Do you know what specific issues I will run into if I run it with no software modifications (other than codes)?
Car even with hollow DPF would pass annual NV sniff test on rolls, but white car had constant accumulation of soot on the rear, when I could not tell how much was on my lungs. I had ECU reprogrammed and showing DPF as "n/a" but NV did not plug OBD for smog test.
Taking advantage of Bluetec Settlement, I reversed the process and have clean car/clean lungs again.
I strongly advise to drive modern diesels with monitoring system like ScanGauge3. This way you can see the problem developing.
New DPF from forum sponsor sell in the range of $1000, what is far cry from $3000 I was quoted by MB.
Unfortunately the software DPF off doesn't cure the soot
There is no recordable difference in mpg between periods of driving with DPF or hollow DPF.
I also could not notice any difference in the power, or throttle response.
The only difference was soot.
Reading between the lines: If MD is fine running without an exhaust, that makes it sound like I could just disconnect the sensors to solve my DPF problems.
Right now I am getting P242f at startup => drive some => limp mode => + codes P244b and P0299
The car (named Big Don, long story) has 170K miles and some other issues. Engine runs great. I don't want to spend too much money on it; I just want to drive it as far as it will go.
Disconnecting the sensors will not prevent DPF from clogging, so even if your engine runs great now, it will not last.
As for Bluetec, they also have SCR aka DEF system, who is independent from DPF. When I had DPF delete, the SCR was still working, what made reversing the process much easier.
What is your DPF load showing now?
