2016 C220d OM651 engine knocking
Old Oct 25, 2025 | 05:29 PM
Yousafk90006's Avatar
2016 Mercedes c220d
Hi,
First time here, figured I’d make a post to see if I can get some help. My C220d engine started to knock during a long drive back from work. The knock gets louder in lower gears. The car has done 125,000km and been serviced at regular intervals by a local garage since my ownership for 2 years (3rd owner). Engine power seems fine and the car is driving, but it does not sound safe to drive. Oil level also looks good, I got it serviced just last month. Im booked in with a local mercedes specialist this week. Any ideas on what it could be and what could have caused it? I’ve researched a bit but cannot find something conclusive with the OM651 engine atleast. I will link a video of the sound below. Any help will be appreciated.
Old Oct 25, 2025 | 08:40 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Could be a bad injector.
Old Oct 26, 2025 | 08:43 AM
2016 Mercedes c220d
I disconnected each injector one by one to check if the sound would change. Sadly no change, knock is still there.
Old Oct 26, 2025 | 10:25 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Running smoothnest test is 1 of the easiest things to do and can answer some questions.
How is the blowby?
Old Oct 26, 2025 | 12:32 PM
2016 Mercedes c220d
How is the blowby?
there as some smoke when i opened the oil cap. Not a crazy amount but i did notice. engine has a rough idle as heard in the video.
Old Oct 26, 2025 | 12:38 PM
2016 Mercedes c220d
Honestly starting to get convinced its a bottom end knock and will need a full rebuild. Its so concerning because the history is good. Serviced regularly with oil changes and the mileage is relatively low. Having a serious “why me” moment. Will see what the mechanic says.
Old Oct 26, 2025 | 04:01 PM
MacVidMB-V8's Avatar
W209, W124
Sounds upper to me.
I spun a couple rod bearings over the years but on bb chev. It had more of a lower frequency syncopated “thump”.
Old Oct 29, 2025 | 02:37 PM
2016 Mercedes c220d
Update, so the mechanic diagnosed it and its a bottom end knock as I suspected. I was quoted €4200 for a replacement engine with 100k km. Gonna be out of a car for a couple weeks. Just unlucky guess **** happens.
